Synchronous Buck Converter Switching
In synchronous buck converters, implementing soft switching is not mandatory but is recommended to minimize ringing and improve efficiency. It is possible to apply soft switching to only one switch, which can simplify control while still providing benefits. The discussion highlights that using a flyback diode can be considered a form of soft commutation, and replacing it with a controlled synchronous rectifier leads to hard commutation. The conversation also notes that the choice between synchronous and non-synchronous designs involves trade-offs between efficiency and control complexity. Overall, soft switching techniques can enhance performance in synchronous buck converters, making them a relevant consideration in design.
sodoyle
TL;DR Summary
Are synchronous buck converters soft switched?
For a synchronous buck converter, does soft switching have to be implemented? I assume there will be some ringing if not. If soft switching is required/recommended, can it be implemented on just one of the switches to simplify control and still have most of the benefit?
I've never used any "soft switching" in my buck converters; is it a common thing? Or is there something special about the synchronous buck design that leads to that need? I've only used bucks with flywheel diodes, not a synchronous lowside switch...
Do you have any links to discussions about "soft switching" in DC-DC converters?
It's just possible to get a higher efficiency with synchronous. Of course that comes at the cost of increased control complexity and an extra FET so it's really just a matter of playing the tradeoff game.
Here's a few open access paper discussing soft switching in synchronous converters
https://jpels.org/digital-library/manuscript/file/16893/9_JPE-15-04-044.pdf
https://www.hindawi.com/journals/ape/2008/862510/
https://www.researchgate.net/publication/26530476_A_Novel_Soft-Switching_Synchronous_Buck_Converter_for_Portable_Applications
I believe a simple flyback diode would be classed as “soft commutation”. If you parallel the flyback diode with a MOSFET you can improve efficiency by reducing the flyback diode voltage drop. The gate of the parallel MOSFET would need a control signal from somewhere, and could then be called “synchronous rectification” or even “hard commutation” because it is forced.
I've never heard of it as "soft commutation" just because of the diode. The anti-parallel diode is used in a lot converters with "soft commutation" though. That's largely because the schottky diode is often a better diode than the FET's body diode. Some type of diode is needed, body or anti-parallel, to implement deadtime which ensures both switches aren't on at the same time during commutation. The external diode is a way to reduce dead time losses.
If a switch such as a diode turns on or off through it's inherent characteristics and position in the circuit, then it is "soft commutation". If it switches because it is controlled by an external signal then it is "hard commutation". The anti-parallel diode, or the body diode across a mosfet is inherent = soft commutation, the mosfet is controlled = hard commutation. If you replace the diode with a controlled synchronous rectifier, then it becomes hard commutation for both the on and off transitions.
Y. Chéron (auth.), C. Goodman (eds.) - Soft Commutation - Springer Netherlands (1992)
4.1 INTRODUCTION
In the Chapter 3, it has been shown that AC supply of inductive or capacitive loads can be achieved very satisfactorily (high efficiency, low distortion). It has also been shown that the performance of these resonant inverters was tightly linked to the commutation process in these switching devices all of which execute one controlled switching and one inherent switching.
We will define as a soft-commutated direct converter a converter only involving switches, each of these switches having at most one controlled switching and at least one inherent switching, the controlled and inherent switchings being if necessary different from one switch to another. So the soft commutation is not compatible with totally controlled switches. In soft-commutated converters the power transfer is controlled by means of switches or by a set of switches with thyristor or dual thyristor switching features.
The term 'soft commutation' is legitimate since those switches that have one controlled switching and one inherent switching can be fitted with lossless snubbers (a series inductor when turn on is controlled or a parallel capacitor when turn off is controlled) so that the switching losses are considerably reduced.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
