- #36
ffp
- 97
- 5
cnh1995 said:I belive you are drawing incorrect conclusions by mixing up many things at a time.
Yeah, I'll try to not mix things up. I too feel I'm going in circles, but mostly because I'm not focusing where matters.
I was re-reading the thread and I'll try to put what I think as simply as I can.
There are 4 scenarios:
A.1) generator alone with load gets turbine speed increased
A.2)generator alone with load gets field current increased
B.1) generator in grid gets turbine speed increased
B.2) generator in grid gets field current increased
I will make affirmations about the scenarios and would like to be corrected when wrong.
A.1) increasing turbine speed increases Ea (=KΦω), which increases Vt (=Ea-IajXs). Both terminal voltage (Vt) and active power (P) increases. Since the angle between Ia and Vt didn't change, reactive power (Q) remains unchanged.
A.2) Increasing If will increase Φ which increases Ea(=KΦω), which increases Vt(=Ea-IajXs). However, P (=τω) remains unchanged. For that to happen, the angle between Ea and Vt, ad well as Vt and Ia must change, so reactive power (Q) changes.
B.1) increasing ω (τω) governor means increasing P (=τω). Since the grid fixates ω and Vt, there is an increase in the opposing EM torque, which reduces ω, but makes τ increase, after a transitory. So the turbines speed is still synchronous speed, but it's torque is higher. Result is higher P and no change in Q.
B.2) increasing If increases Φ, which increases Ea(=KΦω). P(=τω) remains constant and Vt tries to increase. However Vt is fixated by the grid. So, there is a bigger stator current (Ia), and changes in angles between Ea-Vt and Ia-Vt: Ea-Vt reduces and Ia-Vt increases.This way, P remains constant, but Q increases (angle between Ia and Vt increases). What exactly causes this changes in angles, I'm not sure.There must be several wrong afirmatives there. If you could point them and correct then, or maybe do the same 4 scenarios from scratch, that'd be nice. I know that thinking in terms of all variables (Ea, If, τ,ω,Φ,P,etc) might not be the best way, but that's exactly what i need to understand.
