Syntax of Sum and Integral Notation: Understanding the Differences
In summary, there is generally accepted syntax for changing the order of a subtraction and a sum. When changing the order of a subtraction, the sign of the difference changes, but this does not happen with a sum. This is because the integral is not exactly a sum, but rather the limit of "Riemann" sums. Swapping the limits of integration changes the sign of the entire expression.
OhMyMarkov
83
Hello everyone!
Now this may seem silly to you, but I'm rather interested in syntax on this one:
$\displaystyle \int _a ^b f(x)dx= - \int _b ^a f(x)dx$, but $\displaystyle \Sigma_{n=A} ^B = \Sigma_{n=B} ^A$ i.e. there is no need for a minus sign, is this generally accepted in terms of syntax?
Thank you.
Yes, it is generally accepted that when you change the order of a subtraction you change the sign of the difference. That does not happen with a sum.
If F is an anti-derivative of f, the [tex]\int_a^b f(x)dx= F(b)- F(a)[/tex], not a sum. That's why you have the change in sign: F(a)- F(b)= -(F(b)- F(a)).
You may be thinking that the integral is a sum. While that is not exactly true, it is true that the integral is the limit of "Riemann" sums. But they will be of the form [tex]\sum f(x_i)\Delta x= \Delta x( \sum f(x_i)[/tex] and swapping a and b changes the sign on [tex]\Delta x[/tex] which changes the sign on the entire expression.
FAQ: Syntax of Sum and Integral Notation: Understanding the Differences
What is the notation of sum and integral?
The notation of sum and integral is a way of representing mathematical operations of summation and integration in a concise and standardized way. It includes symbols such as sigma (∑) for summation and the integral sign (∫) for integration.
What is the difference between a sum and an integral?
A sum is a mathematical operation that involves adding together a finite number of terms, while an integral is a mathematical operation that involves finding the area under a curve or the volume of a solid.
How do you read and interpret a sum or integral notation?
To read and interpret a sum notation, start by reading the variable of summation (the letter next to the sigma symbol) and the limits of the summation (the numbers below and above the sigma symbol). Then, substitute the values within the limits into the expression following the sigma symbol and add them together. To read and interpret an integral notation, start by reading the expression inside the integral symbol, then the variable of integration (the letter next to the integral symbol), and finally, the limits of integration (the numbers below and above the integral symbol). Then, use the expression to find the area or volume within the given limits.
What are some common properties of sum and integral notations?
Some common properties of sum and integral notations include commutativity (changing the order of terms does not change the result), associativity (changing the grouping of terms does not change the result), and distributivity (distributing a constant factor to each term does not change the result).
How are sum and integral notations used in real-world applications?
Sum and integral notations are used in a variety of real-world applications, such as calculating the total distance traveled by a moving object, finding the average value of a function, and determining the area under a probability distribution curve. They are also commonly used in physics, engineering, and economics to model and analyze various systems and phenomena.
