Synthesis of a re-designed E. coli genome
In summary: Some of the unnatural amino acids could be found naturally, but others may only be found in the lab or in very specific environmental conditions.
Ygggdrasil
Insights Author
4,199
TL;DR Summary
Scientists redesigned a bacterial genome to omit three codons and synthesized the bacteria, which could be useful tools in biotechnology.
All organism on Earth use a genetic code consisting of 64 three-letter codons to encode the 20 amino acids found in proteins. Scientists in the field of synthetic biology have long sought to expand the genetic code to allow encoding of more than 20 natural amino acids found in most organisms. Some synthetic biologists have worked toward this goal by engineering the ribosome to decode four-letter codons, while others have sought to add more letters to the DNA alphabet. Another approach to expand the genetic code involves removing some of the redundancy of the natural genetic code to make room for additional amino acids. Previous work had completely removed all 321 instances of one stop codon from the widely studied bacteria E. coli. Published today in the journal Nature, scientists report synthesis of a functional E. coli genome with all instances of three codons removed from the genome.
Fredens et al. Total synthesis of Escherichia coli with a recoded genome. Nature. Published online 15 May 2019. https://www.nature.com/articles/s41586-019-1192-5
Abstract:
Nature uses 64 codons to encode the synthesis of proteins from the genome, and chooses 1 sense codon—out of up to 6 synonyms—to encode each amino acid. Synonymous codon choice has diverse and important roles, and many synonymous substitutions are detrimental. Here we demonstrate that the number of codons used to encode the canonical amino acids can be reduced, through the genome-wide substitution of target codons by defined synonyms. We create a variant of Escherichia coli with a four-megabase synthetic genome through a high-fidelity convergent total synthesis. Our synthetic genome implements a defined recoding and refactoring scheme—with simple corrections at just seven positions—to replace every known occurrence of two sense codons and a stop codon in the genome. Thus, we recode 18,214 codons to create an organism with a 61-codon genome; this organism uses 59 codons to encode the 20 amino acids, and enables the deletion of a previously essential transfer RNA.
The work was based a prior study by the same group published in 2016 that showed the feasibility of removing the three codons from a segment of the E. coli genome. In their new work, the scientists synthesize and assemble the full, re-coded E. coli genome. The bacteria with the redesigned genomes are functional and viable, though they grow somewhat more slowly than their natural counterparts. While the first bacterial genome (consisting of ~1 million base pairs) was synthesized back in 2010, the 4 Mb E. coli genome represents the largest full genome synthesized to date. The work now allows the researchers the freedom to insert genes to allow these engineered bacteria to produce proteins containing unnatural amino acids, which will likely be the subject of future work. Removal of additional codons may be difficult as demonstrated by previous studies, though more extensive re-coding could be possible in the future.
Popular press coverage:
https://arstechnica.com/science/201...-own-e-coli-genome-compress-its-genetic-code/https://www.statnews.com/2019/05/15/recoded-bacteria-genome-made-from-scratch/
Likes Greg Bernhardt, jim mcnamara and BillTre
Biology news on Phys.org
Ygggdrasil said:
Summary: Scientists redesigned a bacterial genome to omit three codons and synthesized the bacteria, which could be useful tools in biotechnology.
What would be some applications?
1. With three unused codons, scientists could engineer the bacteria to use up to three additional unnatural amino acids, which it could then incorporate into proteins. These unnatural amino acids could be used to provide the proteins with new functions not found in nature.
2. Because the bacteria no longer use some of the same codons, they may be resistant to almost all viruses (bacteriophages) that might try to attack it (since presumably the virus genes would contain the unused codons and would not be produced correctly in the engineered bacteria). This would be very helpful to prevent problems associated with phage infections when bacteria are used in large-scale industrial settings.
Sounds like a challenge to the viruses' evolutionary abilities.
I would expect:
  1. phages would be selected to avoid using of the incorrect codons in the few proteins (relative to the bacteria) that they make
  2. phages would then be able to evolve utilization the novel codons to make new proteins that might incorporate the novel amino acids
These guys would in a sense be in a new evolutionary cyber-universe defined by their different codons.
The chemical nature of the new amino acids could be important.
Would they be naturally found pretty commonly but not genome encoded amino acids (such as posttranscriptionally modified amino acids found in some proteins (methylation, ubiquitination, ...))? In that case they should be easily metabolized. If not they might be poisonus or have some other effect. Of curse the modified bacteria would then have to have some novel way to deal with the novel amino acid, which would present an additional problem for the engineers.
FAQ: Synthesis of a re-designed E. coli genome
1. What is the purpose of synthesizing a re-designed E. coli genome?
The purpose of synthesizing a re-designed E. coli genome is to create a modified version of the bacteria's genetic code. This can allow for the production of new proteins or the alteration of existing ones, potentially leading to improved functions or traits in the bacteria. It can also help in studying the effects of specific genetic changes on the bacteria's behavior and metabolism.
2. How is the re-designed E. coli genome synthesized?
The synthesis of a re-designed E. coli genome involves using a laboratory technique called DNA synthesis, where short DNA sequences are assembled together to create a longer, complete genome. This process can be done manually or with the help of computer programs that aid in designing the desired genetic code.
3. What are the potential applications of a re-designed E. coli genome?
A re-designed E. coli genome can have various applications in the fields of biotechnology, medicine, and research. It can be used to produce new proteins for medical treatments, create genetically modified organisms for agriculture, or study the effects of genetic changes on bacterial behavior and metabolism.
4. Are there any potential risks associated with synthesizing a re-designed E. coli genome?
As with any genetic modification, there are potential risks associated with synthesizing a re-designed E. coli genome. These risks include unintended consequences on the bacteria's behavior or the environment, as well as the possibility of the modified bacteria escaping and causing harm. It is essential to follow strict safety protocols and regulations when working with genetically modified organisms.
5. What are the challenges in synthesizing a re-designed E. coli genome?
The main challenges in synthesizing a re-designed E. coli genome include the complexity of the genetic code and the potential for errors during the synthesis process. It can also be time-consuming and expensive to synthesize a large genome. Additionally, ethical considerations and safety regulations must be taken into account when conducting this type of research.
10K
