Synthesis of Fluorescents AuNCs
  • Thread starter Thread starter Estefani
    Gold Nano
The discussion centers on the synthesis of Fluorescent Gold Nanoclusters (AuNC) as part of a chemistry degree project. The researcher has successfully produced nanostructures under 5 nm but is facing issues with fluorescence emission during characterization. The synthesis involves using synthetic peptides, HAuCl4 as a gold precursor, ascorbic acid as a reducing agent, and NaOH to adjust pH. Despite initial fluorescence observed with a 365 nm lamp, no emission is detected with molecular fluorescence equipment, prompting a request for assistance in identifying potential errors or omissions in the synthesis process. The researcher seeks feedback on the excitation frequency used in the fluorescence tests.
Estefani
TL;DR Summary
Hi there. I present the approach of the synthesis of AuNC with the aim that they have the fluorescence property, i am looking for some help to identify failures in my procedure and achieve success in obtaining the product. Thanks!
Hi everyone, as a degree project to obtain a chemistry degree, i am developing the Synthesis of Fluorescent Gold Nanoclusters (AuNC). I have investigated the route to obtain nanoestructures of nanometric size less than five nanometers, reaction conditions, and so far i have managed to obtain a reaction product with no surface plasmon band and in the DLS analysis i have managed to show the size less than 5 nm. However, the fluorescence spectroscopy characterization doesn't give me any fluorescence emission results from my AuNCs. So, i'm going to share with you the synthesis route that i have proposed and other details, so that you please help me identify errors or omission of steps and possible causes of why i don't obtain fluorescent NCs.
As a bingind ligand i am using synthetic peptides, the peptide sequence that i am using for the tests is: Ac-CTKKCGLWSILKGVGKI-NH2
The Au-Pep ratios is 1:3
As a gold precursor i am using HAuCl4
The solvent is water
The reducing agent is Ascorbic Acid
To increase the reaction to alkaline pH i am using NaOH
Synthesis:
The first step is to increase the pH of the peptide to generate the availability of its negative charges, then to a 3mM solution of peptide i add NaOH up to pH 12 and i take it to the ultrasonic bath equipment for 10 minutes. After 10 minutes i add the 1mM gold solution and a little amount of ascorbic acid 50mM, then 10 minutes in the ultrasonic bath equipment and finally i pass it to the agitation equipment for 24h at 37ºC.
After this procedure, i run a test with a 365 nm lamp and the product fluoresces, but when i take it to the molecular fluorescence equipment i get no emission result and i don't realize what i'm omitting in order no to get a product that fluoresces. :c
Plese help me!
Thank you so much!
Note: The reducing agent that i proposed is with the aim of not using a strong, toxic and polluting agent. The peptide is provide by the university and i cannot change it. Please, let me know if you need more details to understand what's going on with this procedure.
Chemistry news on Phys.org
What excitation frequency are you using for the molecular fluorescence equipment?
11K
