System and phase space trajectory
In summary, phase space trajectories are paths through configuration space that include a particular parametrization. They are not necessary for describing physical systems as the trajectory can be found by solving the equation of motion directly. The concept of phase space is often used in classical systems, but it is interchangeable with the solutions to the equations of motion.
Logic Cloud
23
To what extent do phase space trajectories describe a system? I often see classical systems being identified with (trajectories in) phase space, from which I get the impression these trajectories are supposed to completely specify a system. However, if you take for example the trajectory x^2+p^2=1 for a one-dimensional harmonic oscillator, it is still left open if x(t=0)=0 or x(t=0)=1 which corresponds to two different parameterizations of the circle. This leads me to ask: what is the role of phase space trajectories in the description of physical systems?
A phase trajectory, by definition, includes a particular parametrization in its specification. It's a path through configuration space, with a path being defined as a continuous map from an interval in the real numbers to the path's range. So, ##x^2 + y^2 = 1## isn't a trajectory, it's just a curve. A corresponding trajectory would be ##t\in[0,1) \rightarrow (\cos t, \sin t)##, etc. You can always reparametrize, but then you have a different trajectory.
I see. So there really isn't any need for the concept of phase space for describing physical systems, since the trajectory can be found by just solving the equation of motion directly. My question was motivated by the classical variant of the Dirac-Von Neumann axioms where a classical system is associated with phase space, but maybe I'm reading too much into it.
Trajectories in phase space are just geometric representations of the solutions to the equations of motion. It's not one or the other, they're interchangeable.
Phase space trajectories play a crucial role in the description of physical systems, but they do not completely specify a system. Phase space, which is a mathematical space that represents all possible states of a system, is a useful tool for analyzing and understanding the behavior of a system. The trajectories in phase space show the evolution of a system over time, and they provide valuable information about the system's dynamics.
However, as the example of the one-dimensional harmonic oscillator mentioned, the phase space trajectory alone does not fully describe the system. The initial conditions, such as the position and momentum of the oscillator at t=0, also play a significant role in determining the behavior of the system. These initial conditions are not explicitly shown in the phase space trajectory, but they are essential for understanding the system's behavior.
Furthermore, in more complex systems, the phase space trajectory can become chaotic or unpredictable, making it impossible to fully determine the system's future behavior from the trajectory alone. In these cases, other factors such as external influences or quantum effects must also be considered.
In summary, phase space trajectories are a valuable tool for understanding the behavior of physical systems, but they do not provide a complete description of the system. Other factors, such as initial conditions and external influences, must also be taken into account for a comprehensive understanding of a system.
FAQ: System and phase space trajectory
What is a system in the context of phase space trajectory?
A system in the context of phase space trajectory refers to a physical or mathematical entity that undergoes a change or transformation over time. This can include physical systems, such as a pendulum swinging back and forth, or abstract systems, such as a mathematical model describing the behavior of a population.
What is phase space trajectory?
Phase space trajectory is a mathematical concept that describes the path of a system through its possible states over time. It is represented as a plot of the system's variables against each other, with time as the independent variable. Phase space trajectory can help visualize and analyze the behavior of complex systems.
How is phase space trajectory related to phase space?
Phase space trajectory and phase space are closely related concepts. Phase space refers to the set of all possible states that a system can occupy, while phase space trajectory tracks the path of a system through these states over time. In other words, phase space is the space in which the trajectory exists.
What is the significance of studying phase space trajectory?
Studying phase space trajectory can provide valuable insights into the behavior of complex systems. It can reveal patterns and relationships that may not be apparent from simply observing the system's behavior over time. Additionally, analyzing phase space trajectory can help predict future behavior and make informed decisions.
How is phase space trajectory used in different fields of science?
Phase space trajectory has applications in various fields of science, including physics, chemistry, biology, and engineering. It is used to study the behavior of physical systems, chemical reactions, biological processes, and complex systems in engineering. It is also a useful tool in data analysis and modeling in these fields.
