LEO31
- 11
- 4
I’m trying to calculate the system curve of an already existing plant, the complexity lies in having 2 different lines, each with its respective pump
1- A substance contained in a closed tank with a liquid level of 40 ft connected to pump 1.
2- a closed tank of pure water connected to pump 2
The two lines will merge together inside a static mixer (resulting into a single current with different physical properties than the 2 starting lines) and will need to travel across a heat exchanger changing its temperature and pressure and therefore physical properties, again.
I’ve only done this type of calculation by hand with a basic line with only one fluid that needs to go from point A to point B with a couple of valves in between, nothing this major and I don’t really know where to start nor if some software is perhaps necessary.
