MHB System of congruences with no solution
  • Thread starter Thread starter vincentvance
    System
The discussion centers on proving that the system of congruences x ≡ 5 (mod 6) and x ≡ 7 (mod 15) has no solution. To understand this, it's essential to analyze the implications of each equation under modulo 3, as both 6 and 15 are multiples of 3. The first equation leads to x ≡ 2 (mod 3), while the second results in x ≡ 1 (mod 3), creating a contradiction. The clarification provided explains that if x ≡ 5 (mod 6), it can be expressed as a multiple of 3 plus 2, confirming the inconsistency. This analysis highlights the lack of a common solution for the system.
vincentvance
Hello,
I am trying to prove that the system
x ≡ 5 (mod 6)
x ≡ 7 (mod 15)
has no solution. This example is done in my textbook and they say one should first assume that there is a solution x, and that when taking classes mod 6 the second equation implies that 2x ≡ 2 (mod 6). After this the example continues and I can follow the remaining steps, but this particular part I don't understand. What does it mean to "take classes mod 6" and why does the second equation imply that 2x ≡ 2 (mod 6)?
Any help is greatly appreciated.
vincentvance said:
Hello,
x ≡ 5 (mod 6)
x ≡ 7 (mod 15)
You might find it easiest to understand this by working mod 3, using the fact that 6 and 15 are both multiples of 3. In fact, if $x \equiv 5\pmod6$ then $x\equiv2\pmod3$. But if $x\equiv7\pmod{15}$ then $x\equiv1\pmod3.$
I feel like such an idiot, but I don't understand why for example if x ≡ 5 (mod 6) then x ≡ 2 (mod 3).
Think of it from the basic definition. If x ≡ 5 (mod 6), it means that $x$ is a multiple of 6, plus 5. Say $x = 6k+5$, for some integer $k$. You can write that as $x = 3(2k+1) + 2$. In other words, $x$ is a multiple of 3, plus 2. That is the same as saying x ≡ 2 (mod 3).
Ah. Of course, now it makes sense. Thank you so much!
First trick I learned this one a long time ago and have used it to entertain and amuse young kids. Ask your friend to write down a three-digit number without showing it to you. Then ask him or her to rearrange the digits to form a new three-digit number. After that, write whichever is the larger number above the other number, and then subtract the smaller from the larger, making sure that you don't see any of the numbers. Then ask the young "victim" to tell you any two of the digits of the...
  • · Replies 27 ·
