MHB System of Equations: (2x-1)(2y-1)
The discussion focuses on solving a system of equations involving variables a, b, x, and y, specifically ax + by = 4, ax² + by² = -3, and ax³ + by³ = -3. The values for a and b are derived as a = (4y + 3)/(x(y - x)) and b = (-4x - 3)/(y(y - x)). Substituting these into the third equation leads to the expression 4xy + 3x + 3y - 3 = 0. The conclusion drawn is that the best deduced form for (2x - 1)(2y - 1) is 4 - 5(x + y), which is seen as unsatisfactory. An alternative expression involving (2x + 3/2)(2y + 3/2) yields a more conclusive result of 21/4.
juantheron
If a\;,b\;,x\;,y satisfy \begin{Bmatrix} ax+by=4\\\\ <br /> ax^2+by^2=-3 \\\\ <br /> ax^3+by^3=-3 \\\\ <br /> \end{Bmatrix}. Then (2x-1)(2y-1)=
Mathematics news on Phys.org
Solve the first two equations for $a$ and $b$. You should get $a = \dfrac{4y+3}{x(y-x)}$, $b = \dfrac{-4x-3}{y(y-x)}.$ Now substitute those values of $a$ and $b$ into the third equation. That should lead to $4xy+3x+3y-3=0.$
At that point I run into trouble. The best that you can deduce about $(2x-1)(2y-1)$ from that last equation is that $(2x-1)(2y-1) = 4-5(x+y)$, which does not seem like a satisfactory answer. If instead the question had asked for $\bigl(2x+\frac32\bigr)\bigl(2y+\frac32\bigr)$ then you could have re-written $4xy+3x+3y-3$ as $\bigl(2x+\frac32\bigr)\bigl(2y+\frac32\bigr) -\frac{21}4$ to give the answer $21/4$, which somehow seems to be more like the sort of conclusion that the question calls for.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
