System of equations: finding a plane
In summary, the conversation discusses solving a system of equations and finding the vectors r(1,1,0,0) and s(-3,0,-2,1). The solution is determined to be x1= x2- 3x4+ 5, x3= -2x4+ 4, and x4= 0, and can be written as (x2, x2, 0, 0)+ (-3x4, 0, -2x4, x4)+ (5, 0, 4, 0).
Catchfire
30
Solve the following system of equations:
2x1 - 2x2 -3x3 = -2
3x1 -3x2 -2x3 + 5x4 = 7
x1 - x2 -2x3 -x4 = -3
Ok so I solved the system and got:
x1 -x2 = 5
x3 = 4
x4 = 0
so I've got a point (5,0,4,0) but the answer is r(1,1,0,0) + s(-3,0,-2,1) + (5,0,4,0)
How do I get the other vectors?
x1 -x2 = 5
x3 = 4
x4 = 0
how? :confused:
x1= 5, x2= 0 is one pair of numbers that satisfy x1- x2= 5.
However, your "solution" is wrong. For example, x1= 2, x2= 0, x3= 2, x4= 1 satisfy the initial equation but none of x1- x2= 5, x3= 4, or x4= 0 are satisfied.
2x1 - 2x2 -3x3 = -2
4x3 + 8x4 = 16
x3 + 2x4= 4
x3 + 2x4 = 4
x1 - x2 +3x4 = 5
x3 + 2x4 = 4
x1 = x2 - 3x4 + 5
x3 = -2x4 + 4
Looks like I missed adding the bolded term. This is correct now I hope.
How do I find r(1,1,0,0) and s(-3,0,-2,1)?
Catchfire said:
2x1 - 2x2 -3x3 = -2
4x3 + 8x4 = 16
x3 + 2x4= 4
not following that :confused:
Yes, that is correct. And now you are saying that any (x1, x2, x3, x4) satisfying those four equations can be written as (x1, x2, x3, x4)= (x2- 3x4+ 5, x2, -2x4+ 4, x4)= (x2, x2, 0, 0)+ (-3x4, 0, -2x4, x4)+ (5, 0, 4, 0)= x2(1, 1, 0, 0)+ x4(-3, 0, -2, 1)+ (5, 0, 4, 0).
AHHH thank you so much, I was pulling my hair out over here. I knew it had to be something pretty straight forward.
Related to System of equations: finding a plane
What is a system of equations in relation to finding a plane?
A system of equations is a set of two or more equations with multiple variables that are used to solve for the coordinates of a plane in three-dimensional space.
How do you solve a system of equations to find the equation of a plane?
To solve a system of equations for a plane, you need to find the values of the variables that satisfy all of the equations. These values can then be used to write the equation of the plane in the form Ax + By + Cz = D, where A, B, and C are the coefficients of the variables and D is a constant.
What types of equations are typically used in a system of equations for finding a plane?
The equations used in a system of equations for finding a plane are typically linear equations, as they represent lines in three-dimensional space. These equations can be in the form of x = a, y = b, or z = c to represent a specific coordinate, or in the form Ax + By + Cz = D to represent a line.
What information is needed to create a system of equations to find a plane?
To create a system of equations to find a plane, you need to know at least three points on the plane or two points and the direction vector of the plane. This information can be used to write equations that will intersect at the desired plane.
What is the importance of finding the equation of a plane using a system of equations?
Finding the equation of a plane using a system of equations is important in many fields such as engineering, physics, and mathematics. It allows us to accurately represent and analyze the behavior of three-dimensional objects and systems, and is essential in solving real-world problems involving planes and their interactions with other objects and forces.
