System of Equations II: Evaluate p+q+r+s & 64p+27q+8r+s
In summary, we are given a system of equations and are asked to evaluate two expressions. By substituting specific values of $n$, we can simplify the given expressions to $a_n = (2n-1)^3$ for all $n$. By comparing the coefficients of $n^3$ in this simplified expression, we can find the values of $p+q+r+s$ and $64p+27q+8r+s$.
anemone
MHB
POTW Director
3,883
115
Consider the system of equations:
$p+8q+27r+64s=1$
$8p+27q+64r+125s=27$
$27p+64q+125r+216s=125$
$64p+125q+216r+343s=343$
Evaluate $p+q+r+s$ and $64p+27q+8r+s$.
Mathematics news on Phys.org
[sp]Let $$\begin{aligned}a_n &= pn^3 + q(n+1)^3 + r(n+2)^3 + s(n+3)^3 \\ &= (p+q+r+s)n^3 + 3(q+2r+3s)n^2 + 3(q+4r+9s)n + (q+8r+27s).\qquad(*) \end{aligned}$$ We are told that $a_1=1^3$, $a_2 = 3^3$, $a_3 = 5^3$ and $a_4 = 7^3$. So for those four values of $n$, $a_n = (2n-1)^3$. But a cubic polynomial is determined by its values at four points, and therefore $$a_n = (2n-1)^3\qquad(**)$$ for all $n$.
Compare the coefficients of $n^3$ in (*) and (**) to get $p+q+r+s = 8$.
Then put $n=-4$ in (*) and (**) to get $(-4)^3p + (-3)^3q + (-2)^3r + (-1)^3s = (-9)^3$, or $64p+27q+8r+s = 729.$[/sp]
Here is my solution:
a) Evaluate \(\displaystyle p+q+r+s\)
Multiply the first equation by -1, the second by 3 the third by -3 and the system becomes:
\(\displaystyle -p-8q-27r-64s=-1\)
\(\displaystyle 24p+81q+192r+375s=81\)
\(\displaystyle -81p-192q-375r-648s=-375\)
\(\displaystyle 64p+125q+216r+343s=343\)
Adding we get:
\(\displaystyle 6p+6q+6r+6s=48\)
Hence:
\(\displaystyle p+q+r+s=8\)
b) Evaluate \(\displaystyle 64p+27q+8r+s\)
Multiply the first equation by -56, the second by 140 the third by -120 and the fourth by 35 and the system becomes:
\(\displaystyle -56p-448q-1512r-3584s=-56\)
\(\displaystyle 1120p+3780q+8960r+17500s=3780\)
\(\displaystyle -3240p-7680q-15000r-25920s=-15000\)
\(\displaystyle 2240p+4375q+7560r+12005s=12005\)
Adding, we get:
\(\displaystyle 64p+27q+8r+s=729\)
I simply solved another 4X4 system (using a CAS) to determine the values by which to multiply the given equations. Opalg's solution is much more elegant. :D
Adding we get:
Hence:
Adding, we get:
Thank you for participating to both of you! Both are genius and perfect solutions to me, honestly speaking, albeit MarkFL's has cheated a bit in his method. (Tongueout)
@Opalg, I really like your method, in fact, I like all of your posts so very much!:)
MarkFL said:
To the corner with me...(Dull)
(Smirk)
Please come back and don't stand(or sit?) in the corner, my sweetest admin!:eek: I can overlook this if... if you cook a nice meal for me!(Emo)
$p+8q+27r+64s=1$
Hello.
I, as always, the more gross. :eek:
I follow the succession (up):
[tex]4^3p+5^3q+6^3r+7^3s=7^3[/tex]
[tex]3^3p+4^3q+5^3r+6^3s=5^3[/tex]
[tex]2^3p+3^3q+4^3r+5^3s=3^3[/tex]
[tex]1^3p+2^3q+3^3r+4^3s=1^3[/tex]
[tex]0^3p+1^3q+2^3r+3^3s=-1^3[/tex]. (a)
[tex]-1^3p+0^3q+1^3r+2^3s=-3^3[/tex]. (b)
[tex]-2^3p-1^3q+0^3r+1^3s=-5^3[/tex]. (c)
[tex]-3^3p-2^3q-1^3r+0^3s=-7^3[/tex]. (d)
[tex]-4^3p-3^3q-2^3r-1^3s=-9^3[/tex]
Therefore:
[tex]4^3p+3^3q+2^3r+1^3s=+9^3=729[/tex]
Now:
[tex](a)-(d)=27p+9q+9r+27s=342 \rightarrow{}3p+q+r+3s=38[/tex]. (e)
[tex](b)-(c)=7p+q+r+7s=98[/tex]. (f)
[tex](f)-(e)=4p+4s=60 \rightarrow{}p+s=15[/tex]. (g)
For (e):
[tex]3p+q+r+3s=38[/tex]
[tex]45+q+r=38 \rightarrow{}q+r=-7[/tex]
Therefore:
[tex]p+s+q+r=15-7=8[/tex]
Regards.
mente oscura said:
Hello.
Therefore:
Now:
For (e):
Therefore:
Regards.
Hey mente oscura, thanks for participating and you know what, my method is exactly the same as yours! I say our method is a good one too!:eek:
FAQ: System of Equations II: Evaluate p+q+r+s & 64p+27q+8r+s
What is a system of equations?
A system of equations is a set of two or more equations that share the same variables. The solution to a system of equations is a set of values that satisfy all of the equations in the system.
What is the purpose of evaluating p+q+r+s & 64p+27q+8r+s?
The purpose of evaluating p+q+r+s & 64p+27q+8r+s is to find the values of the variables p, q, r, and s that satisfy both equations simultaneously. This will give us the solution to the system of equations.
How do you solve a system of equations?
To solve a system of equations, you can use various methods such as substitution, elimination, or graphing. These methods involve manipulating the equations to isolate one variable and then substituting its value into the other equation to find the remaining variables.
Can a system of equations have more than one solution?
Yes, a system of equations can have more than one solution. This occurs when the equations are dependent, meaning they share the same solution, or when there are more variables than equations, resulting in infinitely many solutions.
What is the importance of systems of equations in science?
Systems of equations are important in science as they allow us to model and solve real-world problems. They are used in various fields such as physics, chemistry, and engineering to describe relationships between different variables and to make predictions based on these relationships.
