System of First-Order ODES
In summary, the conversation discusses an exercise involving an initial value problem and the use of Euler's method to solve it. The exercise also delves into the concept of stability of numerical methods and how the Euler method can become unstable for a great step $h$. The conversation also includes some clarifications on the power iteration method and finding the real solution of the system of First-Order ODES.
evinda
MHB
3,836
Hello! (Wave)
I am looking at the following exercise:
Consider the initial value problem
$\left\{\begin{matrix}
x''(t)=x(t)\\
x(0)=a\\
x'(0)=b
\end{matrix}\right.$
Write it as a system of First-Order ODES with suitable initial values and show that Euler method can get unstable for a great step $(h)$.
That is the solution that the assistant of the prof gave us:
$$y_1=x \Rightarrow y_1'=x'=y_2 | y_1(0)=x(0)=a \\ y_2=x' \Rightarrow y_2'=x''=y_1 | y_2(0)=x'(0)=b $$
$$\binom{y_1}{y_2}'=\begin{pmatrix}
0 & 1\\
1 & 0
\end{pmatrix} \binom{y_1}{y_2} \text{ with } \binom{y_1(0)}{y_2(0)}=\binom{a}{b}$$Euler method:
$$\binom{y_1^{n+1}}{y_2^{n+1}}=\binom{y_1^n}{y_2^n}+h \begin{pmatrix}
0 & 1\\
1 & 0
\end{pmatrix} \binom{y_1^n}{y_2^n}=\binom{y_1^n+hy_2^n}{y_2^n+hy_1^n} \\ \binom{y_1^{n+1}}{y_2^{n+1}}= \begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix} \binom{y_1^n}{y_2^n}$$$$b=-a$$
The exact solution of the initial value problem is ($t^n=nh$)
$\binom{y_1(t)}{y_2(t)}=e^t \binom{a}{-a} \Rightarrow \binom{y_1(t^n)}{y_2(t^n)}=e^{-t^n} \binom{a}{-a}=e^{-nh} \binom{a}{-a}$, $h$ constant, $n \to +\infty, y \to 0$.
$y=e^{-t}$Euler method
$\binom{y_1^1}{y_2^1}=\begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix} \binom{y_1^0}{y_2^0}=\begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix} \binom{a}{-a}=(1-h) \binom{a}{-a}$
$\binom{y_1^2}{y_2^2}=\begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix} \binom{y_1^1}{y_2^1}=(1-h)^2 \binom{a}{-a}$
$\dots \dots \dots$
$\binom{y_1^n}{y_2^n}=(1-h)^n \binom{a}{-a}$
$|1-h|>1 \Rightarrow h>2$.
First of all, how do we find that $\binom{y_1^1}{y_2^1}=\begin{pmatrix}
1 & h\\
h & 1
1 & h\\
h & 1
\end{pmatrix} \binom{a}{-a}=(1-h) \binom{a}{-a},\binom{y_1^2}{y_2^2}=\begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix} \binom{y_1^1}{y_2^1}=(1-h)^2 \binom{a}{-a}$, $\dots $,$\binom{y_1^n}{y_2^n}=(1-h)^n \binom{a}{-a}$?
I found the following:$\binom{y_1^1}{y_2^1}=\begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix} \binom{a}{b}, \binom{y_1^2}{y_2^2}=\begin{pmatrix}
1+h^2 & 2h\\
2h & h^2+1
\end{pmatrix} \binom{a}{b}, \binom{y_1^3}{y_2^3}=\begin{pmatrix}
1+3h^2 & h(h^2+3)\\
h(h^2+3) & 1+3h^2
\end{pmatrix} \binom{a}{b}$
Am I wrong? (Worried) If not, how could we find the general formula? Also, don't we find the real solution of the system of the First-Order ODES as follows?$\begin{vmatrix}
-\lambda & 1\\
1& -\lambda
\end{vmatrix}=0 \Rightarrow \lambda^2=1 \Rightarrow \lambda=\pm 1$.
Now we are looking for the eigenvectors.
For $\lambda=1$:
$\begin{pmatrix}
-1 & 1 \\
1 & -1
\end{pmatrix} \binom{u}{w}=\binom{0}{0} \Rightarrow \left\{\begin{matrix}
-u+w=0\\
u-w=0
\end{matrix}\right. \Rightarrow \left\{\begin{matrix}
w=u\\
u=w
\end{matrix}\right. \overset{\text{ we set } u=1}{\Rightarrow } u=w=1$
For $\lambda=-1$:
$\begin{pmatrix}
1 & 1 \\
1 & 1
\end{pmatrix} \binom{u}{w}=\binom{0}{0} \Rightarrow u+w=0 \Rightarrow u=-w \overset{\text{ we set w=-1}}{\Rightarrow } u=1=-w$So the solution is of the form:
$\binom{y_1}{y_2}=c_1 \binom{1}{1} e^{t}+ c_2 \binom{-1}{1} e^{-t}$
Using the initial conditions, I got the following:
$\binom{y_1}{y_2}= \frac{a+b}{2} \binom{1}{1} e^t+ \frac{b-a}{2} \binom{-1}{1}e^{-t}$How could we show that for a great step $h$ the method can get unstable? (Thinking)
Mathematics news on Phys.org
Hello, thank you for bringing this exercise to our attention. I can provide some insights on the questions you have raised.
Firstly, to answer your question on how we find the general formula for $\binom{y_1^n}{y_2^n}$, we can use the power iteration method. This method involves repeatedly multiplying a vector by a matrix and taking the limit as the number of iterations approaches infinity. In this case, the matrix is $\begin{pmatrix}
1 & h\\
h & 1
\end{pmatrix}$ and the vector is $\binom{a}{b}$. This method allows us to find the general formula as $(1-h)^n\binom{a}{b}$.
Moving on to your question on finding the real solution of the system of First-Order ODES, the method you have used is correct. However, there is a slight error in your calculation for the eigenvector corresponding to $\lambda=-1$. It should be $\binom{1}{-1}$ instead of $\binom{-1}{1}$. This will result in the correct solution that you have mentioned.
To show that for a great step $h$ the Euler method can get unstable, we can use the concept of stability of numerical methods. A numerical method is considered stable if small changes in the initial conditions or parameters do not result in large changes in the solution. In this case, for a great step $h$, the value of $(1-h)^n$ will become very small and close to 0. This means that even a small error in the initial conditions or parameters will result in a large error in the solution. This shows that the Euler method can get unstable for a great step $h$.
I hope this helps answer your questions. Please let me know if you have any further doubts or concerns. I am always happy to help clarify any scientific concepts. Good luck with your exercise!
FAQ: System of First-Order ODES
What is a system of first-order ODES?
A system of first-order ODES, or ordinary differential equations, is a set of equations that describes the relationships between the rates of change of multiple variables over time. These equations involve only first derivatives of the variables and can be solved using various mathematical methods.
What are the applications of a system of first-order ODES?
A system of first-order ODES has various applications in science and engineering, including modeling physical systems, predicting population growth, and analyzing chemical reactions. It is also used in fields such as economics, biology, and neuroscience to understand dynamic systems.
How are systems of first-order ODES solved?
There are different methods for solving systems of first-order ODES, including analytical methods, numerical methods, and graphical methods. Analytical methods involve finding exact solutions using algebraic manipulations, while numerical methods use computer algorithms to approximate solutions. Graphical methods involve plotting the solutions to visually understand the behavior of the system.
What is the difference between an initial value problem and a boundary value problem for a system of first-order ODES?
An initial value problem is a type of problem where the initial values of the variables are known, and the goal is to find the values of the variables at a specific time. A boundary value problem, on the other hand, involves finding the values of the variables at two or more specific times, known as boundary conditions. The solutions to these types of problems may differ depending on the nature of the system of first-order ODES.
What are some common techniques for analyzing systems of first-order ODES?
Some common techniques used to analyze systems of first-order ODES include phase plane analysis, stability analysis, and bifurcation analysis. Phase plane analysis involves plotting the solutions in a two-dimensional space to understand the behavior of the system. Stability analysis is used to determine the long-term behavior of the system, while bifurcation analysis studies how the solutions change as parameters in the system are varied.
