Systems of equations using partial derivatives
In summary, the conversation discusses a system of equations and addresses two questions. The first question asks if the system can be solved for x, y, z as functions of a and b near a specific point. The second question asks for the partial derivative of x with respect to a, considering a and b as independent variables. The conversation also discusses the use of Jacobian matrix and clarifies the variables as either dependent or independent in the equations. Finally, it is determined that the values from part 1 should be left in terms of the variables rather than being solved numerically.
sandy.bridge
798
Consider the system of equations
[tex]x^2y+za+b^2=1[/tex]
[tex]y^3z+x-ab=0[/tex]
[tex]xb+ya+xyz=-1[/tex]
1. Can the system be solved for [tex]x, y, z[/tex] as functions of [tex]a[/tex] and [tex]b[/tex] near the point [tex](x, y, z, a, b)=(-1, 1, 1, 0, 0)[/tex]?
2. Find [tex]\frac{\partial x}{\partial a}[/tex] where [tex]x=x(a, b)[/tex]
For part 1, do I merely plug in [tex](x, y, z)=(-1, 1, 1)[/tex] and then solve the system of linear equations with the variables a and be remaining in the function?
Part 2 really confuses me. My textbook has taught us one notation, and then it states a question in this format. For example, often it will say something such as [tex](\frac{\partial z}{\partial x})_w[/tex] to notify when something is independent or dependent. Can someone clarify what the question is stating?
Not sure about part 1. I believe part two is telling you to take the partial derivative of the system of linear equations with respect to a, all the while regarding both a and b as independent variables...
Someone can clarify this.
That can't be true...
Okay... I just looked at my notes, and part 1 can be solved via Jacobian matrix. Take the determinant of the matrix, and if this value is nonzero, then that assures us these can be solved with respect to x, y, z.
Okay, thanks.
For part 2, x=x(a, b) is stating that x is the dependent variable, and a and b are both independent variables. Can anyone clarify where the y and z variables stand in this instance? How do I tell if they are dependent, or independent variables.
Thanks
x, y, z are dependent, and a and b are independent.
okay, i figured out both part 1 and 2. Does anyone know if I should be plugging in the values from part 1 into x, y, z, a, b to get a numerical answer, or should I leave it in terms of x, y, z, a, b?
Related to Systems of equations using partial derivatives
1. What is a system of equations using partial derivatives?
A system of equations using partial derivatives is a set of equations that involve multiple variables and their partial derivatives. These equations are used to describe relationships between multiple variables in a system, and can be solved to find the values of these variables at specific points.
2. What are partial derivatives?
Partial derivatives are derivatives that measure the rate of change of a function with respect to one of its variables, while holding all other variables constant. They are represented by symbols such as ∂ (pronounced "del") and are used in multivariable calculus to analyze functions with multiple variables.
3. Why are partial derivatives important in systems of equations?
Partial derivatives are important in systems of equations because they allow us to find the rate of change of a function with respect to each of its variables. This is useful in solving systems of equations, as we can use partial derivatives to find the values of each variable at specific points.
4. How do you solve a system of equations using partial derivatives?
To solve a system of equations using partial derivatives, you first need to take the partial derivative of each equation with respect to each variable. Then, set these partial derivatives equal to each other and solve for the variables. This will give you the values of the variables at the specific point you are interested in.
5. What are some real-world applications of systems of equations using partial derivatives?
Systems of equations using partial derivatives have many real-world applications, such as in economics, physics, and engineering. For example, they can be used to model and analyze systems involving multiple variables, such as supply and demand, heat transfer, and fluid dynamics.
