Systems of Non-Linear equations
In summary, In this conversation, the speaker is trying to find the other points of intersection for a system of equations. They have solved for x and gotten "2", but are struggling with the second equation. They find the other two points by solving for y and substituting -1 into the equation.
datafiend
31
Hi all. I'm really at a loss on how to find the "other" points of intersection for this system of equations: x^2-y=4
x^2+y^2=4
Obviously we have a parabola and circle.
I have solved for x and got "2", and plugged that back into get "0". However the answer has 4 points, the others being +/- \sqrt{3} , +/-1.
How do you get the other 2 points? I tried to use Cramers, but I got a zero in the denominator.
Any help?
Mathematics news on Phys.org
Hi (Wave),
I don't know Cramers, but I think the reason why you're not getting all the solutions is because you've isolated for $x$ or $y$ and did not check the $\pm$ when you took the square root.
$ x^2-y=4$
$x^2=4+y$
$|x| = \sqrt{4+y}$
$x =\pm\sqrt{4+y}$
Personally, I would keep the $x$ as $x^2$ and solve:
I have these two equations:
$x^2=4-y^2$
$x^2-y=4$
What happens when I substitute the first equation into the second?
So,
I get 4-y^2-y=4?
Do I factor that out? Maybe use the quadratic formula?
There is no need, just simple factoring!
Well, we can subtract both sides to get rid of the $4$.
$-y^2-y=0$
Now factor,
$-y(y+1)=0$
Either $y=0$ or $y+1=0$. What are the solutions? (Wondering)
yes, I'm struggling with this...
ok. i got y=0 or y=-1.
at this point, do I just put the -1 into x and solve?
So, given $-y^2-y=0$, we want to find the values of $y$ such that the equation equals 0. If we factor the equation, this becomes clear:
$-y(y+1)=0$
If either $y=0$ or $y+1=0$, the whole expression will be equal to 0. Which are those $y$ values? Do you understand what I have said so far?
EDIT:
Yes, those are correct! Just put them back into the equation and solve for the corresponding $x$ values.
Yeah. I got the other coordinates by substituting the y=-1 into the other equation.
Thank you for your patience. I'm done for the day.
Alternatively,
$x^2 - y = 4$ and $x^2 + y^2 = 4$
$4 = 4$ therefore,
$x^2 - y = x^2 + y^2$
$-y = y^2$ [subtracting x^2 from both sides]
$0 = y^2 + y$
$y(y + 1) = 0$
$y = 0$ and $y = -1$ now substitute these in.
FAQ: Systems of Non-Linear equations
What are non-linear equations?
Non-linear equations are mathematical expressions that cannot be written in the form of y = mx + b, where m and b are constants. In other words, the variables in a non-linear equation have powers other than 1, making the graph of the equation a non-straight line.
What is a system of non-linear equations?
A system of non-linear equations is a set of two or more non-linear equations that are solved simultaneously to find the values of the variables that satisfy all the equations in the system. These equations can have multiple variables and can be solved using various methods such as substitution or elimination.
Why are non-linear equations important?
Non-linear equations are important in many fields of science, such as physics, engineering, and biology, as they can model real-life phenomena more accurately than linear equations. They can also be used to solve complex problems and make predictions.
What are some methods for solving systems of non-linear equations?
Some common methods for solving systems of non-linear equations include substitution, elimination, and graphing. Other methods such as Newton's method and the bisection method can also be used, but these are more advanced and require knowledge of calculus.
Can a system of non-linear equations have more than one solution?
Yes, a system of non-linear equations can have more than one solution. This is because non-linear equations can have multiple points of intersection on a graph, where the values of the variables satisfy all the equations in the system. These points of intersection represent the different solutions to the system of equations.
