Table of value for y=2-3(5^x+4), plus its transformation from y=5^x.
You had the second column right - but you'd then add two to get the third column. So your third column had the right numbers - but it should have had the wrong sign.
calcdummy
Describe the transformations that must be applied to the graph of y=5^x to obtain the graph of y=2-3(5^x+4) and complete the following table.
y=5^x
(-1,1/5)
(0,1)
(1,5)
(2,25)
(3,125)
y=-3(5^x)
y=2-3(5^x+4)
y=5^x , y=2-3(5^x+4)
y=5^x
(-1,1/5)
(0,1)
(1,5)
(2,25)
(3,125)
y=-3(5^x)
(-1,-3/5)
(0,-3)
(1,-15)
(2,-75)
(3,-375)
y=2-3(5^x+4)
(-5,3/5)
(-4,3)
(-3,15)
(-2,75)
(-1,375)
What I did to achieve the points in the second column was to multiply the y-coordinates in the first column by -3. Then I proceeded to adding "-4" to the x coordinates and multiplying the y coordinates by -1 because of "2-3".
I couldn't check to see if my points are correct on my graphing calculator because I didn't know how to input y=2-3(5^x+4). Anyway on the the transformations which I presumed to be:
Shifted to the left by 4(d)
Reflected in x-axis (because I figured "a" would end up being -1)
After that I'm stumped.
What I think the parameters are: a=-1 k=0 d=4 c=0
y=5^x
(-1,1/5)
(0,1)
(1,5)
(2,25)
(3,125)
y=-3(5^x) y=2-3(5^x+4)
y=5^x
(-1,1/5)
(0,1)
(1,5)
(2,25)
(3,125) y=-3(5^x)
(-1,-3/5)
(0,-3)
(1,-15)
(2,-75)
(3,-375)
y=2-3(5^x+4)
(-5,3/5)
(-4,3)
(-3,15)
(-2,75)
(-1,375)
No. "-3A" is not "2-3A". Given that when x= -1, -3(5^x) is -3/5, then 2- 3(5^x) is 2- 3/5= 2/5. You had already accounted for the "-" when you multiplied by -3 to get the second column. The new thing in the third column is the "2". Get your third column by adding 2 to the second column.
After that I'm stumped. What I think the parameters are: a=-1 k=0 d=4 c=0
Are you saying that everything prior to the third column is correct and that I should just add "2" to both the x and y-coordinates?
I'm sorry but could someone please help me out... HallsofIvy's comment left me a bit confused.
y=2-3(5^x+4) solved is y=-3(5^x)-10
Try using that equation in the last column. Should just have an increment of -10 in the y's.
You can sub y=2-3(5^x+4) in wolfram alpha (online) to see if the solved equation satisfies the points for the last column.
Lemme know if that helps at all or if you have any questions.
Best of luck
Not quite understanding your math.
2- 3/5 = 2/5?
2- 3/5 = 7/5 = 1 2/5
so you can write it as either 7/5 or 1 2/5.
Here's how I'd show the step-by-step transform:
[tex] \begin{array} \\
x & 5^x & 5^x+4 & 3(5^x+4) & 2-3(5^x+4) \\
-1 & 0.2 & 4.2 & 12.6 & -10.6 \\
0 & 1 & 5 & 15 & -13 \\
1 & 5 & 9 & 27 & -25 \end{array} [/tex]
Unless you're required to reduce this to one multiplication and one addition, I don't really understand why you're asked to show ##-3(5^x)##.
Note - in support of HallsofIvy's point - that 2-3A = -3A + 2.
FAQ: Table of value for y=2-3(5^x+4), plus its transformation from y=5^x.
What is a table of values?
A table of values is a chart that shows the input and output values of a function. In other words, it lists the x-values and their corresponding y-values for a given equation or expression.
2. How do you create a table of values for y=2-3(5^x+4)?
To create a table of values for this equation, you would simply choose a few values for x, plug them into the equation, and solve for y. Repeat this process until you have enough data points to plot on a graph.
3. What is the transformation from y=5^x to y=2-3(5^x+4)?
The transformation is a translation of the original function y=5^x. The equation has been shifted 4 units to the left and 2 units down.
4. How does the transformation affect the graph of y=5^x?
The transformation affects the graph by shifting it to the left by 4 units and down by 2 units. This means that all points on the graph will be shifted to the left by 4 units and down by 2 units.
5. Can you explain the significance of the transformation in terms of the original function y=5^x?
The transformation affects the original function y=5^x by changing its coordinates and therefore changing its shape and position on the graph. It also shows how manipulating the equation can result in a different graph with different points and properties.
