Tangent Bundles, T(MxN) is Diffeomorphic to TM x TN
  • Thread starter Thread starter BrainHurts
    Bundles Tangent
The discussion centers on proving that the tangent bundle T(MxN) is diffeomorphic to TM x TN for smooth manifolds M and N. Participants analyze the structure of tangent vectors at points in the product manifold, specifically addressing the representation of vectors in T(MxN) and their relation to tangent spaces TM and TN. There is confusion regarding the assumptions made about vector fields and the need for careful mapping between the tangent spaces. One participant suggests finding a map that accurately translates vectors from T(MxN) to the product of the tangent spaces. The conversation highlights the complexities involved in establishing the diffeomorphism and the necessity for precise definitions in the proof.
BrainHurts
If M and N are smooth manifolds, then T(MxN) is diffeomorphic to TM x TN
So I'm here
let ((p,q),v) \in T(MxN)
then p \in M and q \in N and v \in T(p,q)(MxN).
so T(p,q)(MxN) v = \sum_{i=1}^{m+n} v_{i}\frac{\partial}{∂x_{i}}|_{(p,q)}
= \sum_{i=1}^{m} v_{i}\frac{\partial}{∂x_{i}}|_{p} + \sum_{i=}^{m+1} v_{i}\frac{\partial}{∂x_{i}}|_{q}
not sure if this is it?
You kind of assume that \frac{\partial}{\partial x^i} are vector fields on both M\times N and N. I think you should be a little more careful than this...
Hi Micro, I'm not sure I understand what you mean, am am assuming however that
\sum_{i=1}^{m} v_{i}\frac{\partial}{∂x_{i}}|_{p} and \sum_{i=}^{m+1} v_{i}\frac{\partial}{∂x_{i}}|_{q}
are bases for TM and TN respectively and I'm not sure if that's good enough.
Well, you assume \frac{\partial}{\partial x_i}\vert_p is both in T_pM and T_pN. You can't do that.
v = \sum_{i=1}^{m} v_{i}\frac{\partial}{∂x_{i}}|_{(p,q)} + \sum_{i=}^{m+1} v_{i}\frac{\partial}{∂x_{i}}|_{(p,q)}
so i need to find a map that takes v \rightarrow (w,y)
where w\inTpM and y\inTpN
and (w,y) \in TpM x TqN
does this sound better? I was thinking about this problem a lot. I'm not sure if that's a diffeo right off the get.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 18 ·
