Tangent equation for two points.
In summary: It's like driving a car without knowing how to turn the wheel . You will only end up in trouble.It is very important to know that a differentiable function at a point a can't have more than one tangent line . This is basically what we mean by f'(x) exists . Now, suppose you have a function that has a discontinuity at a point ,say, b then we cannot draw a tangent line at this point . So , continuity is necessary for differentiability . But , suppose that a function is continuous on an open interval can we conclude it is differentiable at any point in the interval ?The function is continuous on the interval , so it is differentiable at that point.
Petrus
702
Hello MHB,
I am doing some old exam and got less knowledge for this problem.
consider the graph of the function
\(\displaystyle g(x)=\frac{1}{x}, \ x\neq 0\)
the point \(\displaystyle \left(3,-1 \right)\) lies on two tangents to the graph. Decide tangents equation.
My progress
well I derivate and find the slope
\(\displaystyle g'(x)=\ln(x)\) so the slope is \(\displaystyle m=\ln(3)\)
so the tangents equation is \(\displaystyle y=\ln(3)(x-3)-1\) is this correct? I am supposed to get two tangent equation:confused:
Regards,
\(\displaystyle |\pi\rangle\)
Petrus said:
well I differentiated and find the slope
I think you got confused . Try to differentiate again .
I have done to much integrate today...
I mean \(\displaystyle -\frac{1}{x^2}\) and we get \(\displaystyle y=-\frac{1}{9}(x-3)-1\) But is this correct method? How shall I find second tangent point
Regards,
If $f$ is differentiable at a point $p$ , can it have more than one tangent line at $p$ ?
The point $(3,-1)$ does not lie on the curve, so it does not make sense to look for the tangent at that point. What you need to do is to find the equation of the tangent at a general point on the curve, say the point $(p, 1/p)$, and then apply the condition for that tangent to go through the point $(3,-1)$.
Zaid,
I actually honestly not 100% sure if it can or not, I keep thinking but I don't really know and interested if it can.
Hello Opalg,
You are obviously correct.. I did not even think about that if it is in the point \(\displaystyle \frac{1}{3} \neq -1\)
I get the tangent equation for \(\displaystyle (p, 1/p)\)
\(\displaystyle y=-\frac{1}{p^2}(x-p)+\frac{1}{p}\)
replace x and y with the point etc we get \(\displaystyle a_1=1 \ a_2=-3\)
so the two tangent line is \(\displaystyle y=-x+2, \ y=-\frac{x}{9}-\frac{2}{3} \)
that agree with the facit
Thanks for the help and fest respond from you both !
Regards,
Here is a pre-calculus technique:
Let the tangent line be:
\(\displaystyle y=mx+b\)
Now, equate this to the function:
\(\displaystyle mx+b=\frac{1}{x}\)
\(\displaystyle mx^2+bx-1=0\)
Since the line is tangent, there will be 1 repeated root, hence the discriminant is zero:
\(\displaystyle b^2+4m=0\)
\(\displaystyle m=-\left(\frac{b}{2} \right)^2\)
Hence, the tangent line is:
\(\displaystyle y=-\left(\frac{b}{2} \right)^2x+b\)
We are told it must pass through the point \(\displaystyle (3,-1)\) so we find:
\(\displaystyle -1=-\left(\frac{b}{2} \right)^2(3)+b\)
Thus:
\(\displaystyle 3b^2-4b-4=0\)
\(\displaystyle (3b+2)(b-2)=0\)
For:
i) \(\displaystyle b=-\frac{2}{3}\,\therefore\,m=\frac{1}{9}\)
The tangent line for this root is:
\(\displaystyle y=-\frac{1}{9}x-\frac{2}{3}\)
ii) \(\displaystyle b=2,\therefore\,m=-1\)
\(\displaystyle y=-x+2\)
It is very important to know that a differentiable function at a point \(\displaystyle a\) can't have more than one tangent line . This is basically what we mean by \(\displaystyle f'(x)\) exists . Now, suppose you have a function that has a discontinuity at a point ,say, \(\displaystyle b\) then we cannot draw a tangent line at this point . So , continuity is necessary for differentiability . But , suppose that a function is continuous on an open interval can we conclude it is differentiable at any point in the interval ?
Remember that a differentiable function at a point means that we can draw '' a unique tangent line '' at this point .
By the way . Solving lots of problems will not enhance ''understanding the concept'' .
FAQ: Tangent equation for two points.
What is the tangent equation for two points?
The tangent equation for two points is a mathematical formula that represents the slope of a line passing through those two points. It is expressed as y = mx + b, where m is the slope and b is the y-intercept.
How do you find the slope of a line using the tangent equation for two points?
To find the slope of a line using the tangent equation, you must first determine the coordinates of the two points. Then, you can use the formula m = (y2 - y1) / (x2 - x1), where (x1, y1) and (x2, y2) are the coordinates of the two points.
Can the tangent equation be used for any two points on a graph?
Yes, the tangent equation can be used for any two points on a graph. However, the resulting line may not always be a straight line, as it depends on the values of m and b in the equation.
What does the y-intercept represent in the tangent equation for two points?
The y-intercept, represented by the value b in the equation, is the point where the line intersects the y-axis. It is the value of y when x equals 0.
Is the tangent equation for two points the same as the point-slope form?
No, the point-slope form is y - y1 = m(x - x1), where (x1, y1) is a point on the line and m is the slope. The tangent equation, y = mx + b, is a different form that is used specifically for finding the slope of a line passing through two points.
