Tangent of function and its limit position
In summary, the equation for the tangent line of y=xe^{\frac{1}{x}} at point x=\alpha is y-\alpha e^{\frac{1}{\alpha}}=\frac{(\alpha-1)e^{\frac{1}{\alpha}}}{\alpha}(x-\alpha). To find the limit position of the tangent, one must rearrange the equation into slope-intercept form and take the limit of the slope and y-intercept as \alpha \rightarrow +\infty.
gruba
206
Find tangent line of [itex]y=xe^{\frac{1}{x}}[/itex] at point [itex]x=\alpha[/itex] and it's limit position when [itex]\alpha \rightarrow +\infty[/itex].
Tangent of [itex]y=f(x)[/itex] at point [itex]M(x_0,f(x_0))[/itex]: [tex]y-y_0=f^{'}(x_0)(x-x_0)[/tex]
Applying the above equation for tangent of function,
[tex]y_0=\alpha e^{\frac{1}{\alpha}}, f^{'}(x_0)=\frac{(\alpha-1)e^{\frac{1}{\alpha}}}{\alpha}, x_0=\alpha[/tex]
gives
[tex]y-\alpha e^{\frac{1}{\alpha}}=\frac{(\alpha-1)e^{\frac{1}{\alpha}}}{\alpha}(x-\alpha)[/tex]
How to find limit position of a tangent? Is it a limit of [itex]y[/itex] when [itex]\alpha \rightarrow +\infty[/itex]?
The question is not expressed very clearly. I am not aware of any concept of a 'limit position' of a line.
However, from the context, one can make a pretty confident guess that the question is trying to ask if there is a line to which the tangent lines become asymptotically 'closer' (in some as yet undefined sense) as ##\alpha\to\infty##.
A line is fully defined by its x intercept and its gradient. Does the ##\lim_{\alpha\to\infty}## of the y intercept and/or the gradient exist? If so, what are they? If you use them to define a line, that may be the line that the teacher is looking for.
I agree with Andrewkirk. You should rearrange the equation from point-slope form into slope-intercept form. Then you will be able to clearly see what happens to the slope and y-intercept as alpha goes to infinity.
For your slope, ##\lim_{\alpha \to \infty} \frac{(\alpha -1)}{\alpha} e^{\frac1\alpha}## should be pretty clear if you look at the fraction part separate from the exponential part.
For your y-intercept, once you rearrange, that should become pretty clear as well.
Related to Tangent of function and its limit position
1. What is the definition of tangent of a function?
The tangent of a function is a trigonometric function that represents the ratio of the length of the opposite side to the length of the adjacent side in a right triangle.
2. How is the tangent of a function related to its limit position?
The limit of the tangent of a function at a given point is equal to the slope of the function at that point.
3. What is the difference between the limit of a function and the limit of the tangent of that function?
The limit of a function represents the value that the function approaches as the input approaches a certain value, while the limit of the tangent of the function represents the slope of the function at that point.
4. Can the tangent of a function have a limit at a point where the function is undefined?
Yes, the tangent of a function can have a limit at a point where the function is undefined, as long as the slope of the function approaches a finite value at that point.
5. How can the limit of the tangent of a function be used to determine the continuity of the function?
If the limit of the tangent of a function at a certain point is equal to the slope of the function at that point, then the function is continuous at that point.
  • Linear and Abstract Algebra
