Tangent Plane Problem: Where am I wrong?
In summary: I will finish that sentence for you: and ( -8(sqrt2)/(sqrt5) , -2(sqrt2)/(sqrt5) , 2(sqrt2)/(sqrt5) ). Just substitute those values for x_0, y_0, z_0 in2x_0\lambda= 4, 4y_0\lambda= 2, and 8z_0\lambda= 4 and see that they work.
gikiian
98
1. Homework Statement :
Find the points on the hyperboloid of two sheets with equation x²-2y²-4z²=16 at which, the tangent plane is parallel to the plane 4x-2y+4z=5.
The hyperboloid with two sheets: x²-2y²-4z²=16
The given plane: 4x-2y+4z=5
Equation of tangent plane: Fx(x-x₀) + Fy(y-y₀) + Fz(z-z₀) = 0 ;
Fx, Fy and Fz are partial derivatives
3. The Attempt at a Solution :
For the hyperboloid, we can say that
F(x,y,z)=> x² - 2y² - 4z² - 16= 0​
Equation of the tangent plane is given by:
Fx(x-x₀) + Fy(y-y₀) + Fz(z-z₀) = 0​
so we need to find Fx, Fy and Fz.
Fx = 2x
Fy = -4y
Fz = -8z​
At P(x₀,y₀,z₀) on the hyperboloid, the partial derivatives will be:
Fx = 2x₀
Fy = -4y₀
Fz = -8z₀​
Putting these results in the equation of the tangent plane, we have:
2x₀(x-x₀) - 4y₀(y-y₀) – 8z₀(z-z₀) = 0
(2x₀)x – (4y₀)y – (8z₀)z = 2x₀²-4y₀²-8z₀²​
Since this plane is parallel to the given plane 4x - 2y + 4z = 5, we multiply one of the planes by any constant, say λ, to get the other one. I chose to multiply λ with the equation of the plane tangent to the hyperbpoloid:
λ [ (2x₀)x – (4y₀)y – (8z₀)z = 2x₀²-4y₀²-8z₀² ]​
Next, by comparing the respective co-efficients of x, y and z of the given and the obtained equation, we get:
2x₀ λ = 4 ------------(i)
4y₀λ = 2-------------(ii)
-8z₀λ = 4 ------------ (iii)
( 2x₀²-4y₀²-8z₀² ) λ = 5 ------------- (iv)
From (i), x₀ = 2 / λ -------------(iv)
From (ii), y₀ = 1 / 2λ ---------(v)
From (iii), z₀ = - 1 / 2λ ----------(vi)​
Putting these values in equation (iv), we get:
( 2(2/λ)²-4(1/2λ)²-8(-1/2λ)² ) λ = 5
( 8/ λ² - 1/ λ² - 2/ λ² ) λ = 5
( 5/λ² ) λ = 5
λ² - λ = 0
λ(λ-1 )= 0
λ = 0……… or ……… λ = 1​
Values of x₀, y₀ and z₀ are not possible for λ = 0, hence for λ = 1, we have from eq. (iv), (v) and (vi):
x₀ = 2
y₀ = 1/2
z₀ = -1/2​
Hence, the point on the hyperbola having the tangent plane parallel to the plane is ( 2 , 1/2 , -1/2 )
My comments:
My solution has something wrong in it. Also, this point does not satisfy the equation of the hyperboloid.
The real answers are:
( 8(sqrt2)/(sqrt5) , 2(sqrt2)/(sqrt5) , -2(sqrt2)/(sqrt5) )
Please help me Identify my mistake. Thanks.
gikiian said:
Fx = 2x
Fy = -4y
Fz = -8z​
Why did you get Fz = -8z ?
Find the points on the hyperboloid of two sheets with equation x²-2y²+4z²=16 at which, the tangent plane is parallel to the plane 4x-2y+4z=5.
The hyperboloid with two sheets: x²-2y²+4z²=16
F(x,y,z)=> x² - 2y² + 4z² - 16= 0​
Fx = 2x
Fy = -4y
Fz = -8z​
You have the sign wrong here. [itex]F_z= 8z[/itex]
Fx = 2x₀
Fy = -4y₀
Fz = -8z₀​
Again, sign wrong.
-8z₀λ = 4 ------------ (iii)​
Of course, that should be [itex]8z_0\lambda= 4[/itex]. You could have got these more simply by noting that the normal to the surface, [itex]\nabla x^2- 2y^2+ 16z^2= 2x\vec{i}- 4y\vec{j}+ 8z\vec{k}[/itex] must be parallel to the normal to the plane, [itex]4\vec{i}- 2\vec{j}+ 4\vec{k}[/itex].
Now, this is a major error- and the reason why your answer is not even on the hyperbola. You had the [itex]\lambda[/itex] in the first three equations because the two planes only had to be parallel, not the same plane. But the point must be on[/b[] the hyperbola so you must have
[itex]2x_0^2- 4y_0^2+ 8z_0^2=5[/itex]- there is no "[itex]\lambda[/itex]" here.
(and note the +8, not -8). Finally, it should be equal to 16, not 5!
[itex]z_0= 1/2\lambda[/itex]
( 5/λ² ) λ = 5
λ² - λ = 0​
Again, that last [itex]\lambda[/itex] should not be there- you have only [itex]5/\lambda^2= 5[/itex]. And, it is equal to 16, not 5.
But even if that were correct, you have an algebra error here- [itex](5/\lambda^2)\lambda= 5/\lambda= 5[/itex] gives [itex]1/\lambda= 1[/itex]- there is no subtraction.
[λ(λ-1 )= 0
[itex]5/\lambda^2= 16[/itex] gives [itex]\lambda^2= 5/16[/itex] so that [itex]\lambda= \pm \sqrt{5}/4[/itex]
x₀ = 2
y₀ = 1/2
z₀ = -1/2​
The equations should be [itex]2x_0\lambda= 4[/itex], [itex]4y_0\lambda= 2[/itex], and [itex]8z_0\lambda= 4[/itex]. Solve those with [itex]\lambda= \sqrt{5}/4[/itex] and [itex]\lambda= -\sqrt{5}/4[/itex].
My comments:
@HallsofIvy & Stephen Tahsi:
Sir I am terribly sorry; the equation meant to be a hyperboloid in two sheets, and it it as follows:
x²-2y²-4z²=16​
So Fz=-8z.
The site which you called as the "major error" is basically a concern.
Thanks for tackling :)
P.S. I corrected the problem question above.
FAQ: Tangent Plane Problem: Where am I wrong?
What is the Tangent Plane Problem?
The Tangent Plane Problem is a mathematical concept that involves finding the tangent plane to a given point on a surface. It is commonly used in calculus and differential geometry.
What is the importance of the Tangent Plane Problem?
The Tangent Plane Problem is important in understanding the behavior of a surface at a specific point. It helps in calculating the slope, direction, and curvature of the surface at that point.
How do you solve the Tangent Plane Problem?
The Tangent Plane Problem can be solved by finding the partial derivatives of the surface equation with respect to x and y, and using them to construct the equation of the tangent plane at the given point.
What are some real-life applications of the Tangent Plane Problem?
The Tangent Plane Problem has various applications in fields such as engineering, physics, and computer graphics. It can be used to analyze the stability of structures, determine the direction of motion of an object, and create realistic 3D models.
What are some common mistakes made when solving the Tangent Plane Problem?
Some common mistakes include miscalculating the partial derivatives, using incorrect formulas, and misinterpreting the results. It is important to carefully follow the steps and double-check the calculations to avoid errors.
