Tangent spaces at different points
In summary, the question is how to determine if two points on a manifold have the same tangent space. The answer is that the tangent spaces at different points are always different, but with a connection, you can compare vectors in the tangent spaces. However, the connection is not unique, as it depends on how the transport is done. The Levi-Civita connection is distinguished, but not canonical.
kent davidge
933
56
How do you know whether two points ##p## and ##q## of a manifold have the same tangent space?
If the two tangent spaces are equal, then the vectors in the two tangent spaces are exactly the same. I suspect that it's equivalent to picking a vector at ##p## and dragging it to ##q## and the vector will not change. So perhaps a test to check whether the tangent spaces are the same is to see if the covariant derivatives of any vector at ##p## w.r.t. a vector field which generates flow which maps the point ##q## vanish.
Is this a good test?
That is easy, they don't.
You are misunderstanding how tangent spaces work. The tangent space at every point is a different space. In order to compare vectors in the tangent spaces at two different points, you need what is called a connection. With a connection, you can meaningfullly test whether a vector in the tangent space at ##p## is the same as, or different from, a vector in the tangent space at ##q##. But even with a connection, the tangent spaces themselves are never "the same"; it's meaningless even to ask that. They're distinct spaces.
A tangent space is the pair ##(p,T_pM)##, so even if ##T_pM \cong T_qM## which they usually are, since an n-manifold has tangent spaces which are all isomorphic to ##\mathbb{R}^n##, the tangent spaces themselves are different, because the points ##p## and ##q## are different and the tangents are fixed at these points. A tangent on a parabola is always a straight, and as a vector space isomorphic to ##\mathbb{R}##. Nevertheless are those straights different at different points. And even if we had the same slope at many points, as e.g. on a sine function, they are still different, because their own coordinate systems have different origins. A connection is a possibility to move one to the other. However, this is in general not unique, because it depends on how the transport is done.
Likes cianfa72 and Klystron
Still, I guess the Levi-Civita connection is distinguished , in some respects, albeit not canonical.
He is not referring to the transport being connection dependent (which is rather clear). He is referring to it being generally path dependent.
Likes Klystron
Related to Tangent spaces at different points
1. What is a tangent space at a point?
A tangent space at a point is a mathematical concept used in differential geometry to describe the set of all possible tangent vectors at that point on a specific manifold. It is a vector space that is tangent to the manifold at that point, and it allows for the understanding of the local behavior of the manifold.
2. How are tangent spaces at different points related?
Tangent spaces at different points are related through the concept of smoothness. If a manifold is smooth, then the tangent spaces at different points are all related by smooth transformations, meaning that they can be continuously and smoothly transformed into one another.
3. What is the significance of tangent spaces at different points?
The tangent spaces at different points are significant because they allow for the understanding of the local geometry and behavior of a manifold. They also play a crucial role in the development of differential geometry and its applications in fields such as physics, engineering, and computer science.
4. How are tangent spaces at different points calculated?
Tangent spaces at different points can be calculated using the concept of tangent vectors. These vectors can be defined as directional derivatives of functions on the manifold, and they form a basis for the tangent space at a specific point. Alternatively, tangent spaces can also be calculated using the concept of differential forms.
5. Can tangent spaces at different points be visualized?
Yes, tangent spaces at different points can be visualized in certain cases. For example, in two-dimensional spaces, tangent spaces at different points can be represented as lines passing through the point, and in three-dimensional spaces, they can be represented as planes passing through the point. However, for higher-dimensional spaces, it becomes more challenging to visualize tangent spaces at different points.
  • Differential Geometry
