Tangential acceleration of proton due to a changing magnetic field
In summary, tangential acceleration of a proton in a changing magnetic field occurs due to the Lorentz force acting on the charged particle as it moves through the field. When the magnetic field changes, it induces an electric field, resulting in a force that alters the proton's velocity in a direction tangential to its path. This process illustrates the relationship between electromagnetic fields and charged particle dynamics, highlighting how variations in magnetic fields can influence particle motion through acceleration.
Meow12
45
In earlier learning sequences we described how a static magnetic field cannot change the speed (and therefore kinetic energy) of a free charged particle. A changing magnetic field can, and this is one way particle beams are accelerated. Consider free protons following a circular path in a uniform magnetic field with a radius of 1 m. At t=0s, the magnitude of the uniform magnetic field begins to increase at 0.001T/s. Enter the tangential acceleration of the protons in positive if they speed up and negative if they slow down.
##\displaystyle R=\frac{mv}{qB}##
##\displaystyle R=\frac{mv}{qB}\implies v=\frac{RqB}{m}## where ##v## is the speed of the proton
##\displaystyle\frac{dv}{dt}=\frac{Rq}{m}\frac{dB}{dt}##
On substituting the values, I get ##\displaystyle\frac{dv}{dt}=9.58\times 10^4\ m/s^2##
This answer, however, is incorrect. Where have I gone wrong?
For a circle of radius R,
[tex] E = -\frac{\pi R^2}{2\pi R}\frac{dB}{dt}=-\frac{mv}{2qB}\frac{dB}{dt}[/tex]
Maybe it is worth considered.
But how do we find ##\displaystyle\frac{dv}{dt}##?
Also, why was my solution incorrect?
You should consider not only B, v but also R changes in time.
Likes Meow12
So, the radius R also increases as the speed v increases. But how do we find the tangential acceleration dv/dt?
You can try to get it from the equation I mentioned.
Are you missing an ##R## in the last term?
I don't think so because
[tex]E = -\frac{\pi R^2}{2\pi R}\frac{dB}{dt}=-\frac{R}{2}\frac{dB}{dt}=-\frac{mv}{2qB}\frac{dB}{dt}[/tex]
I do not think so because
Ah yes, you are correct!
Likes anuttarasammyak
Consider the equation that @anuttarasammyak wrote above for the tangential electric field ##E##:$$E=-\frac{R}{2}\frac{dB}{dt}$$What's the relation between an electric field, an electric force and a charge?
Likes Meow12
Plugging in the values, I get ##|E|=5\times 10^{-4}\ N/C##
##\displaystyle a_t=\frac{q|E|}{m}##
Substituting the value of ##|E|##, and the values of ##q## and ##m## for a proton, I get ##a_t=4.79\times 10^4\ m/s^2##, which is the right answer. Thank you so much, both of you. :)
Likes anuttarasammyak and renormalize
FAQ: Tangential acceleration of proton due to a changing magnetic field
What is tangential acceleration of a proton in a changing magnetic field?
Tangential acceleration of a proton in a changing magnetic field refers to the acceleration component that is tangent to the path of the proton. This type of acceleration can occur when the magnetic field changes in magnitude or direction, causing a change in the velocity of the proton along its circular or spiral trajectory.
How is tangential acceleration related to the magnetic field?
Tangential acceleration is related to the magnetic field through Faraday's Law of Induction, which states that a changing magnetic field induces an electric field. This induced electric field can exert a force on the proton, causing it to accelerate tangentially to its path.
What is the formula for calculating tangential acceleration of a proton?
The tangential acceleration \( a_t \) of a proton can be calculated using the induced electric field \( E \) from Faraday's Law: \( a_t = \frac{eE}{m_p} \), where \( e \) is the charge of the proton and \( m_p \) is its mass. The induced electric field \( E \) can be determined from the rate of change of the magnetic flux.
Can a proton experience tangential acceleration in a constant magnetic field?
No, a proton cannot experience tangential acceleration in a constant magnetic field. In a constant magnetic field, the proton experiences centripetal acceleration, leading to circular motion. Tangential acceleration requires a changing magnetic field to induce an electric field.
What are the practical implications of tangential acceleration of protons in changing magnetic fields?
Understanding the tangential acceleration of protons in changing magnetic fields is crucial in various applications, including particle accelerators and magnetic confinement in fusion reactors. It helps in predicting particle behavior, optimizing magnetic field configurations, and improving the efficiency of these technologies.
