Tangents at the pole (polar)
  • MHB
  • Thread starter Amad27
  • Tags
    Polar Pole
In summary: So, really you are finding the derivative of a xy curve, which is just parametric. So in really the derivative at theta something, means you are finding the derivative of a xy function, not with respect to theta. Really.
Amad27
412
In a polar function,
$r = 1 - 2\cos(t)$ what are the tangents at the pole, considering $t$ an angle?
I am not sure what the pole is BUT!
$x = \cos(t) - 2\cos^2(t)$
$y = \sin(t) - \sin(2t)$ $dx/dt = -\sin(t) + 4\cos(t)\sin(t)$
$dy/dt = \cos(t) - 2\cos(2t)$
$dy/dx = \frac{\cos(t) - 2\cos(2t)}{-\sin(t) + 4\cos(t)\sin(t)}$
The pole in polar coordinates is the origin. So you need to find the values of $t$ for which $r=0$.
That can't make sense. How can you find an angle for which the length of a line is equal to 0. That line doesn't exist. It is a single coordinate.
Think about it more carefully and you will see how it makes sense. There are two values of the parameter $t$ at which the curve passes through the origin. Your job is to find the equations of the tangents at those points.
Wait, so the pole is $(r, \theta) = (0, 0)$
But then the denominator becomes 0 for $dy/dx$
Also, I have a major question.
QUESTION:
When you have a polar equation, $r = 1-2\cos(\theta)$
Why is the derivative $dy/dx$ and not $dr/d\theta$
The equation of the curve is $r = 1 - 2\cos\theta.$
If $r=0$ then $1 - 2\cos\theta = 0$, which means that $\cos\theta = \frac12$, and therefore $\sin\theta= \pm\frac{\sqrt3}2.$
You have correctly calculated that $\frac{dy}{dx} = \frac{\cos\theta - 2\cos(2\theta}{-\sin\theta + 4\cos\theta\sin\theta}$. All you now have to do is to insert the above values for $\cos\theta$ and $\sin\theta$ into that formula. That will give you the gradients of the curve when it passes through the origin (and the denominator does not become 0 at those points).
QUESTION:
The question asks for the tangents to the curve. You probably find it easier to describe these using cartesian coordinates rather than polar coordinates.
You have correctly calculated that $\frac{dy}{dx} = \frac{\cos\theta - 2\cos(2\theta}{-\sin\theta + 4\cos\theta\sin\theta}$. All you now have to do is to insert the above values for $\cos\theta$ and $\sin\theta$ into that formula. That will give you the gradients of the curve when it passes through the origin (and the denominator does not become 0 at those points).The question asks for the tangents to the curve. You probably find it easier to describe these using cartesian coordinates rather than polar coordinates.
Geometrically, it still does not make sense. To create an angle, you need two rays. If $r= 0$ then there can't be an angle?
Since $\cos(\theta) = 1/2 \implies \pi/3$
$-\sin(\theta) + 2\sin(2\theta)$
At $\pi/3$ this gives $= -\sqrt{3}/2 + \sqrt{3}$
Perhaps a picture will help. The polar equation $r = 1-2\cos\theta$ gives the black curve. You need to find the tangents at the origin, which are the two green lines.
[graph]vmgasyxoyt[/graph]
Hey there,
So there is an intuition.
You have
$y = f(\theta)$
$ x = g(\theta)$
$\implies \theta = g^{-1}(x)$
$y = f(g^{-1}(x))$
y' = f'(g^{-1}(x)}\cdot \frac{1}{g'(g^{-1}(x))}$$
So, really you are finding the derivative of a xy curve, which is just parametric. So in really the derivative at theta something, means you are finding the derivative of a xy function, not with respect to theta. Really. It is focused on $x$ isn't it?
Can you please read the last paragraph carefully, and respond to it, share thoughts. Possibly confirm. Please. I would really appreciate this favor.
FAQ: Tangents at the pole (polar)
What are tangents at the pole in polar coordinates?
Tangents at the pole in polar coordinates are lines that pass through the pole, which is the origin of the polar coordinate system. They are used to describe the behavior of a function as it approaches the pole.
How are tangents at the pole calculated?
To calculate tangents at the pole, you must first find the slope of the tangent line using the derivative of the function. Then, the equation of the tangent line can be written using the point-slope formula with the coordinates of the pole as the point of tangency.
What is the significance of tangents at the pole in polar coordinates?
Tangents at the pole are important in understanding the behavior of a function at the origin. They can help determine the direction of a curve and the rate of change at the pole. They are also useful in finding local extrema and critical points of a function.
Can tangents at the pole be vertical?
No, tangents at the pole cannot be vertical. This is because the slope of a vertical line is undefined, and the slope of a tangent at the pole must be defined in order to calculate its equation.
How do tangents at the pole relate to polar curves?
Tangents at the pole are used to describe the behavior of polar curves near the pole. They can help determine the shape and direction of a polar curve, as well as identify any points of discontinuity or cusps. They are an important tool in analyzing polar curves and their properties.
