Tarzan Physics Question with Kinematics, Energy, Forces
In summary, Tarzan, weighing 63.0 kg, starts from rest at point A and swings off a cliff 30.0 m above the ground to save Jane, who weighs 50.0 kg and is standing unaware at the base of a tree at point B. Tarzan successfully grabs Jane at point B without hitting the tree, but loses grip of her at point C, 12 m off the ground. Jane propels into the air at an angle of 65 m above horizontal, following a parabolic trajectory. The far side of the crocodile pit is 5.5 m from point C, with no air resistance and a 100% efficient vine. The velocity of Jane at point C is unknown, but
sangdeep
Tarzan (63.0 kg) is trying to save Jane (50.0 kg) from the fast approaching crocodile (who is in the crocodile pit). Tarzan starts from rest at point A and swings off the edge of a cliff 30.0 m above the ground, while hanging on to a vine of a very large tree. At point B, Tarzan grabs Jane who is standing on the ground at the base of the tree (unaware of the approaching croc). Tarzan does not hit the tree. However, clumsy Tarzan loses grip of Jane at point C (the point where the ground and the crocodile pit meets), which is 12 m off the ground. Jane propels into the air at an angle 65 m above the horizontal and she follows a parabolic trajectory. The far side of the crocodile pit is horizontal distance of 5.5 m from point C. Assume no air resistance and the swinging vine is 100% efficient.
1. What is the velocity of Jane at point C, when Tarzan let her go?
2. What is the maximum height that she reaches above the crocodile pit?
3. Does Jane make it past the crocodile pit safely?
4. What is Jane's final velocity upon landing.
So I have a exam, which will have a Question similar to this one. I just don't know to get started with it.
for the swinging thru air part, you can use conservation of mechanical energy (tension is perpendicular to motion, so there are no forces (gravity is represented by potential energy)).
Notice you do not have conservation of momentum.
However, during the short and sweet collision, you do not have conservation of mechanical energy (only in elastic collisions), but, since all external forces are negligible compared to the huge forces of collision, you have conservation of momentum.
So for the first part of swinging, cons of energy, during the collision, cons of mom, second part of swining, cons of energy again.
Related to Tarzan Physics Question with Kinematics, Energy, Forces
1. What is the basic premise of Tarzan Physics?
The concept of Tarzan Physics involves using kinematics, energy, and forces to analyze the motion of Tarzan swinging through the jungle.
2. How is kinematics applied in Tarzan Physics?
Kinematics is used to study the motion of Tarzan as he swings through the jungle, including his velocity, acceleration, and displacement.
3. What role does energy play in Tarzan Physics?
Energy is crucial in Tarzan Physics as it is what allows Tarzan to maintain his swinging motion. The potential and kinetic energy of Tarzan and the vine are constantly changing as he swings.
4. How are forces involved in Tarzan Physics?
Forces such as gravity, tension, and air resistance play a significant role in Tarzan Physics. These forces act on Tarzan and the vine as he swings through the jungle.
5. How does Tarzan's body position affect his motion in Tarzan Physics?
Tarzan's body position is crucial in determining his motion as he swings through the jungle. By changing his body position, Tarzan can control his velocity, acceleration, and the forces acting on him.
11K
10K
