- #36
eviltattooz
- 2
although the adjustment of speed can surely be made by increasing/decreasing voltage and capacitor resistance. different stages of any given tattoo calls for mechanical changes in the machine to increase/decrease force. this is directly related to the mechanical set-up (stroke length, spring compression) which enables the delivery of pigment to the dermis to be delivered in vastly different ways. more elastic parts of the human body will require more/less force depending on the elasticity of the skin, and needle groupings which penetrate the skin are anywhere fron single needles-to groups of 25 or more in both round and flat configurations. you need more of an impact with a higher grouping in order to penetrate efficiently and without doing damage to the skin. and/or not having enough force to dye the dermis permenantly. as all (if not 98%) of all tattoos reqiure different stages of work to be completed -i.e., lining the design, shading, coloring in. which require different needle groupings. (you wouldn't make a painting with a single paintbrush, youd have thin ones, thick ones, broad ones etc.) So as speed can succesfully be changed on a machine through electrical changes and without mechanical adjustment, the relation of any particular machine to the TATTOOING PROCESS- is dependent on BOTH the electrical, and physical properties of the machine being used for that very specific task and the variables that go into it. (needle group, pigment consistency). Most reputable tattoo machine builders are very experienced in the machining of all the materials used, as well as the electrical properties of the machine they are building, and are building each one for a specific use in the field. true tattoo machine builders are craftsmen as are volin makers and watch makers. i know this is an old thread, but to help the last guy who posted here, buy quality equiptment and parts from serious machine builders, tinker,.. and experience the magic and mystery that is the tattoo machine, more coil=more voltage required= more stored power=more force and less magnetic dissipation,--- less coil=less voltage=less stored power=faster dissipation. each has its advantages and disadvantages and can be manipulated with mechanical changes and electrical changes combined- but the puzzle doesn't go together without every piece...now go have fun
