Taylor Development of f(x)=ln(1-x)
  • Thread starter Telemachus
  • Tags
    Taylor
In summary, the conversation discusses finding a Taylor development for the function f(x)=\ln(1-x) using the relation \displaystyle\sum_{n=0}^{\infty}x^n=(1-x)^{-1} and making derivatives. The conversation also explores the use of this relation and the validity of starting the summation at n=1. It is suggested to integrate both sides to get a Taylor expansion of f(x). The conversation ends with a discussion on the interval of convergence and the method outlined for finding the Taylor series.
Telemachus
835
30
Hi there. I have this exercise which I'm trying to solve now. It says:
Using that [tex]\displaystyle\sum_{n=0}^{\infty}x^n=(1-x)^{-1}[/tex] find one Taylor development for the function [tex]f(x)=\ln(1-x)[/tex]
So, I've made some derivatives:
[tex]f^1(x)=\displaystyle\frac{-1}{(1-x)},f^2(x)=\displaystyle\frac{-1}{(1-x)^2},f^3(x)=\displaystyle\frac{-2}{(1-x)^3},f^4(x)=\displaystyle\frac{-6}{(1-x)^4},f^5(x)=\displaystyle\frac{-24}{(1-x)^5}[/tex]
And then:
[tex]\displaystyle\sum_{n=0}^{\infty}\displaystyle\frac{f^b(x_0)(x-x_0)^n}{n!}=-\displaystyle\frac{(x-x_0)}{(1-x_0)}-\displaystyle\frac{(x-x_0)^2}{2(1-x_0)^2}-\displaystyle\frac{2(x-x_0)^3}{6(1-x_0)^3}-\displaystyle\frac{6(x-x_0)^4}{24(1-x_0)^4}-\displaystyle\frac{24(x-x_0)^5}{120(1-x_0)^5}+\ldots+-\displaystyle\frac{(x-x_0)^n}{n(1-x_0)^n}[/tex]
I have two problems with this. In the first place, the general expression that I've found (which is probably wrong) doesn't work for n=0, it does for the others values of n. I thought of starting the summation at 1, but I'm not sure if this is valid. In the second place I don't know how to use the relation the problem gives at the beginning. I can see that I have (1-x_0) for every term, but I couldn't make it fit inside the summation.
So this is what I got: [tex]\displaystyle\sum_{n=1}^{\infty}-\displaystyle\frac{(x-x_0)^n}{n(1-x_0)^n}[/tex]
Bye there, thanks for your help and suggestions.
What is [tex]\int \frac{1}{1-x} dx[/tex]?
The point of the exercise was probably the following. The first derivative gives:
[tex]f^\prime(x)=-(1-x)^{-1}[/tex].
So, using the relation, we get
[tex]f^\prime(x)=\sum_{n=0}^{+\infty}{x^n}[/tex].
Now, integrate both sides to get a Taylor expansion of f.
Now, the method outlined above is a lot easier than your method, since I don't have to make all that differentiations. But I still like your method more, since it gives a general answer, i.e. you've actually calculated the Taylor series with arbitrary x0, while my method only gives a Taylor series around 0...
f'(x)dx, thanks Sethric.
Thank you micromass, nice point. It actually gives an approximation only on the interval of convergence, which goes from -1<x<1, I think it's because this interval is where the function f'(x) is uniformly convergent, but I'm not sure about this. I mean, in the interval where its not uniformly convergent we can't integrate "inside" the summation, right?
FAQ: Taylor Development of f(x)=ln(1-x)
What is the equation for the Taylor Development of f(x)=ln(1-x)?
The Taylor Development for f(x)=ln(1-x) is given by the infinite series:
ln(1-x) = -x - (x^2)/2 - (x^3)/3 - (x^4)/4 - ...
What is the radius of convergence for the Taylor Development of f(x)=ln(1-x)?
The radius of convergence for the Taylor Development of f(x)=ln(1-x) is 1. This means that the series will converge for all values of x within a distance of 1 from the center, which is x=0.
How many terms are needed for a good approximation of f(x)=ln(1-x)?
The number of terms needed for a good approximation of f(x)=ln(1-x) depends on the desired level of accuracy. Generally, the more terms that are included in the series, the more accurate the approximation will be.
What is the importance of the Taylor Development of f(x)=ln(1-x) in mathematics?
The Taylor Development of f(x)=ln(1-x) is important in mathematics because it allows us to approximate the natural logarithm function for values of x close to 0. This can be useful in solving various mathematical problems and in developing other mathematical concepts.
Can the Taylor Development of f(x)=ln(1-x) be extended to other functions?
Yes, the Taylor Development method can be used to approximate other functions as well. However, the specific coefficients and radius of convergence will vary depending on the function. The Taylor Development is a powerful tool in mathematics for approximating functions and solving problems.
