I Taylor expansion about lagrangian in noether
The discussion centers on the mathematical derivation of Noether's theorem, particularly how Lagrangians transform under infinitesimal transformations. It highlights that when Lagrangians differ by a total time derivative of a function, the first-order Taylor expansion suffices to establish equivalence between transformed and original Lagrangians. The key point is that the first-order term leads to a conservation law derived from the Euler-Lagrange equations. The conversation also touches on the possibility of extending these concepts to more general transformations, maintaining the symmetry condition and resulting conservation laws. Understanding these transformations is crucial for grasping the implications of Noether's theorem in physics.
gionole
I was studying a derivation of noether's theorem mathematically and something struck my eyes.
Suppose you have ##L(q, \dot q, t)## and you transform it and get ##L' = L(\sigma(q, a), \frac{d}{dt}\sigma(q,a), t)##. ##\sigma## is a transformation function for ##q##
Let's represent ##L'## by taylor around point 0, which gives us:
##L(q, \dot q) + a\frac{\partial L}{\partial a}\Bigr|_{a=0} + a^2\frac{\partial^2 L}{\partial a^2}\Bigr|_{a=0} + ...##
Now, here is the tricky part: If lagrangians(before and after transformation) are differed by total time derivative of some function, we can say that:
##\frac{\partial L}{\partial a}\Bigr|_{a=0} = \frac{d}{dt}\Lambda##
Note that first order from taylor turned out to be enough, even though taylor only with first order is not the exact(100%) approximation of any ##L##. So it turns out that we use: ##a\frac{\partial L}{\partial a}\Bigr|_{a=0} = a\frac{d}{dt}\Lambda## instead of ##a\frac{\partial L}{\partial a}\Bigr|_{a=0} + a^2\frac{\partial^2 L}{\partial a^2}\Bigr|_{a=0} + ... = \frac{d}{dt}\Lambda##
I am told that we can do this because ##a## is infinetisemal transformation, but still don't get why this works. I know I need to know lie theory to understand this, but isn't there really any other way to somehow grasp it without bunch of math ?
You just need that ##L'## and ##L## should be equivalent Lagrangians, i.e., that there exists a function ##\Omega(q,t)## such that
$$L'[\sigma(q,a),\dot{\sigma}(q,a),t]=L(q,\dot{q},t]+\dot{\Omega}(q,t),$$
where the dots mean total derivatives (symmetry condition).
For an infinitesimal transformation, i.e., ##q'=q+\epsilon \sigma(q,t)## you can make the ansatz ##\Omega(q,t)=-\epsilon \tilde{\Omega}(q,t)## and expand the LHS of the symmetry condition to first order in ##\epsilon##, which then leads to a conservation law for the solutions of the Euler-Lagrange equations.
BTW: That's only the most simple special form of the transformations considered in Noether's theorem. You can extend it to more general transformations,
$$t'=t+\epsilon \Theta(q,\dot{q},t), \quad q'=q+\epsilon Q(q,\dot{q},t).$$
Then
$$\frac{\mathrm{d}}{\mathrm{d} t'} L[q+\epsilon Q,\dot{q}+\epsilon \dot{Q},t+\epsilon \Theta(q,\dot{q},t)]=L(q,\dot{q},t) -\epsilon \dot{\tilde{\Omega}}(q,t).$$
Now again you can expand everything to 1st order in ##\epsilon## to get the symmetry condition, and then there follows again a conservation law for the solutions of the Euler-Lagrange equations.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
