Taylor Expansion for very small and very big arguments
  • Thread starter Thread starter deuteron
    Taylor expansion
deuteron
Expand the given functions for very small and very big arguments ##x## giving ##3## terms
##T_nf[x;a]= \displaystyle\sum_k \frac 1 {k!}\ f^{(k)}|_a\ (x-a)^k##
The function is
$$ f(x)=\sqrt{1-x}$$
and we are expected to expand it using Taylor expansion for very small ##(x<<1)## and very big ##(x>>1)## arguments
My thought process was the following:
$$T_2f[x;x_0]=\sqrt{1-x_0} -\frac 12 \frac 1{\sqrt{1-x_0}}(x-x_0) -\frac 14 \frac 1 {\sqrt{1-x_0}^3}(x-x_0)^2$$
and then assuming small arguments, namely assuming ##x_0<<1##, I did the following approximation:
$$ T_2f[x;x_0]\approx \sqrt{1} -\frac 12 \frac 1 {\sqrt{1}} (x) -\frac 1 4 \frac 1 {\sqrt{1}^3} (x)^2 = 1-\frac 12 x -\frac 14 x^2$$
For big arguments, I assumed ##x_0>>1## and made the following approximation:
$$T_2f[x;x_0]\approx i\sqrt{a} +\frac 12 \frac 1 {i\sqrt{a}} (a) +\frac 14 \frac 1 {i\sqrt{a}^3} a^2$$
However, the real answers are, for small arguments:
$$f(x<<1)= 1-\frac 12 x - \frac 18 x^2$$
and for big arguments:
$$f(x>>1)= i\sqrt{a} \sqrt{1-\frac 1x} = i\sqrt{x} \ (1-\frac 1 {2x} -\frac 1{8x^2})$$
I see that my mistake is to assume the expansion point to be very big instead of assuming big ##x##, but I don't know how to do that, does anyone understand the in between steps for the solution?
Use the binomial expansion: <br /> (1 + x)^{\alpha} = 1 + \alpha x + \frac{\alpha(\alpha - 1)}{2!}x^2 + \dots + \frac{\alpha(\alpha - 1) \cdots (\alpha - n + 1)}{n!}x^n + \dots,\qquad |x| &lt; 1. For small |x|, <br /> f(x) = (1 - x)^{1/2} can be expanded as is. A Taylor series of x^{1/2} about 1 should also yield the same result, bearing in mind that we are looking at (1 - x)^{1/2} not (1 + x)^{1/2}. For large negative x, (1 - x)^{1/2} = (1 + |x|)^{1/2} = |x|^{1/2}(1 + |x|^{-1})^{1/2} can be expanded. For large positive x, f(x) = ix^{1/2}(1 - x^{-1})^{1/2} can be expanded.
