MHB Taylor Series Expansion Explanation
The discussion centers on proving the identity \( S = a^x \) using the Taylor series expansion for the function \( f(x) = a^x \). The participants outline the Taylor series formula and derive the necessary derivatives to show that \( f^{(n)}(0) = (\ln(a))^n \). They connect this to the infinite summation \( S = \sum_{n=0}^{\infty} \frac{(x \ln a)^n}{n!} \), which equals \( e^{x \ln a} \). Additionally, there is a conversation about the constraints on the base \( a \), emphasizing the need for \( a > 0 \) to avoid issues with the logarithm. The proof effectively demonstrates the relationship between the Taylor series and the exponential function.
Sudharaka
MHB
mbeaumont99's question from Math Help Forum,
This is to do with some infinite summation work that we are going through at college at the moment. We have the function \(\displaystyle t_{n} =\frac{(x\ln a)^{n}}{n!}\) and have been substituting in different x and a values to determine a general statement for the infinite summation of the function. I have found that \(\displaystyle S_{n}=a^{x}\)
I need to do a formal proof for this general statement and heard that a Taylor series would be able to do that. If anyone would be able to start me off on this, send me in a different direction, or simply contribute to this thread then I would be extremely appreciative.
Thanks,
mbeaumont99
Hi mbeaumont99,
One thing you can do is to find the Taylor series expansion of \(f(x)=a^{x}\) and see whether it is \(\displaystyle \sum t_{n}\). The Taylor series for the function \(f \) around a neighborhood \(b\) is,
\[f(x)=\sum_{n=0}^{\infty}\frac {f^{(n)}(b)}{n!} \, (x-b)^{n}\]
Of course I am assuming here that the function \(f\) can be expressed as a Taylor series expansion around a neighborhood of \(b\) (that is \(f\) is analytic). To get a more detailed idea about what functions are analytic read this and this. We shall use \(b=0\) so that we get the Maclaurin's series.
\[f(x)=\sum_{n=0}^{\infty}\frac {f^{(n)}(0)}{n!} \, x^{n}\]
Now we have to find out \(f^{(n)}(0)\) with regard to the function \(f(x)=a^{x}\). Differentiating \(f\) a couple of times we can "feel" that \(f^{n}(x)=a^x(\ln(a))^n\,\forall\,n\in\mathbb{N}=\mathbb{Z}\cup\{0\}\). To prove this in a formal manner we shall use mathematical induction.
When \(n=0\), the result is obvious. We shall assume that the result is true for \(n=p\in\mathbb{N}\). That is,
\[f^{(p)}(x)=a^{x}(\ln(a))^p\]
Now consider, \(f^{(p+1)}(x)\).
\[f^{(p+1)}(x)=\frac{d}{dx}f^{(p)}(x)=(\ln(a))^p \frac{d}{dx}a^x=a^x(\ln(a))^{p+1}\]
Therefore by Mathematical induction, \(f^{n}(x)=a^x(\ln(a))^n\,\forall\,\in\mathbb{N}\)
\[\therefore f^{n}(0)=(\ln(a))^n\,\forall\,\in\mathbb{N}\]
Hence,
\[f(x)=\sum_{n=0}^{\infty}\frac{(\ln(a))^n}{n!}\, x^{n}=\sum_{n=0}^{\infty}t_{n}\]
Mathematics news on Phys.org
Thanks,
mbeaumont99
This is asking for the summation:
\( \displaystyle S=\sum_{n=0}^{\infty} \frac{(x\ln(a))^n}{n!} \)
We note the series expansion for the exponential function:
\( \displaystyle e^u=\sum_{n=0}^{\infty} \frac{u^n}{n!} \)
which is convergent for all real or complex \(u\). Put \(u=x\ln(a) \) to get:
\( \displaystyle e^{x\ln(a)}=\sum_{n=0}^{\infty} \frac{(x\ln(a))^n}{n!}=S \)
Now \( x\ln(a) = \ln(a^x) \) so:
\( \displaystyle a^x=e^{\ln(a^x)}=\sum_{n=0}^{\infty} \frac{(x\ln(a))^n}{n!}=S \)
CB
All right!... it seems that we all agree on the identity...
$\displaystyle a^{x}= e^{x\ \ln a}= \sum_{n=0}^{\infty} \frac{(x\ \ln a)^{n}}{n!}$ (1)
Nobody however has imposed constraints on a, so that can a be anything we like?... but in this case what does it happen when is $a=0?$... or when is $a<0$?... better is to avoid problems and impose $a>0$ or critically examine the general case of any real value for a?... a nice question!...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
I expect the implied restriction is that \(a>0\), but I am reasonably sure that once one picks a branch of the logarithm the series converges to the given sum (assuming \( a\ne 0\) ).
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
