Taylor series of 1/ln(t+1) at t=0
  • I
  • Thread starter laurabon
  • Tags
    Calculus
In summary, the Taylor series of \( \frac{1}{\ln(t+1)} \) at \( t=0 \) is derived by expanding the function around \( t=0 \) using the derivatives of the function evaluated at that point. The series expresses \( \frac{1}{\ln(t+1)} \) as an infinite sum of terms involving powers of \( t \) and coefficients based on the function's derivatives. The first few terms provide an approximation of the function near \( t=0 \), capturing its behavior as \( t \) approaches this point.
laurabon
I have tried to use the natural Taylor expansion of ln(t+1)
and working with long division but I get the result 1/t+1/2+t/12−t^2/24+⋯
instead of 1/t+1/2-t/12+t^2/24+... that is the right result
I have tried to do this several time but still don't works. Is there a miscalculation in my long division?
Hard to tell without seeing your calculation.
The Taylor series at a point ##t_0=0## is
f(t)=\sum_{n=0}^\infty \dfrac{(t-t_0)^n}{n!} \left.\dfrac{d^{n}}{dt^n}\right|_{t_0}f(t)=\sum_{n=0}^\infty\dfrac{t^n}{n!}f^{(n)}(0)
so we need primarily the derivatives of ##f(t)=\log(t+1).##
\begin{align*}
f^{(0)}(t)&=\log(t+1)&\quad f^{(0)}(0)=\log(1)=0\\
f^{(1)}(t)&=\dfrac{1}{t+1}&\quad f^{(1)}(0)=\dfrac{1}{0+1}=1\\
f^{(2)}(t)&=-\dfrac{1}{(t+1)^2}&\quad f^{(2)}(0)=-\dfrac{1}{(0+1)^2}=-1\\
f^{(3)}(t)&=\dfrac{2}{(t+1)^3}&\quad f^{(3)}(0)=\dfrac{2}{(0+1)^3}=2\\
&\ldots &\ldots
\end{align*}
Now go on as long as you like and gather what you have.
Likes bhobba and dextercioby
\begin{align*}
&\ldots &\ldots
\end{align*}
I agree with you and mabe is the safest way . About my calculation : I have used also walphram alpha and it says that 1/(x-x^2/2+x^3/6) (I used only these terms for ln(1+t) = 1/t+1/2+t/12−t^2/24
instead 1/log(1+t)=1/t+1/2-t/12+t^2/24 why this happens?
So, what you did was:
$$\ln(1 + t) = t - \frac{t^2} 2 + \frac{t^3} 3 -\frac{t^4}{4} \dots$$$$\frac 1 {\ln(1+t)} = \frac 1 {t - \frac{t^2} 2 + \frac{t^3} 3 -\frac{t^4}{4} \dots} = \frac 1 t + \frac 1 2 + \frac t {12} - \frac {t^2}{24} \dots $$Using polynomial long division?
$$\ln(1 + t) = 1 - t + t^2 - t^3 \dots$$$$\frac 1 {\ln(1+t)} = \frac 1 {1 - t + t^2 - t^3 \dots} = \frac 1 t + \frac 1 2 + \frac t {12} - \frac {t^2}{24} \dots $$Using polynomial long division?
yes. Is it wrong ? the coefficient for log are different because I have used the Talor series but the calculation is that
Sorry, I didn't see the inversion. It wasn't part of your post and was hidden in the title.
Please use https://www.physicsforums.com/help/latexhelp/ and show what you actually did.
You can easily make sign errors in a long division if you aren't careful enough. And to deal with the long denominator is a nightmare, too. You'd probably better solve
1=\left(x-\dfrac{x^2}{2}+\dfrac{x^3}{3}-\dfrac{x^4}{4}\pm \ldots\right)\cdot (a_0+a_1x+a_2x^2+a_3x^4+\ldots)
Likes topsquark and PeroK
Yes you are right , it was my error . I was considering the denominator of taylor expansionfor log(1+x) with factorial but... it doesn't hae factorials... about what you proposed in yyour post , doing multiplication shouldn't a_0 be 0? because on the right I have 1+0x+0x^2=a_0x
If I look at the result, I should have started with ##a_{-1}\dfrac{1}{x}+a_0+a_1x+\ldots ## Then ##a_0## turns out to be a half.
If you only need a few of the first terms, I'd do it like this:
\begin{align*}
\frac{1}{\log(1+t)} &= \frac{1}{t-t^2/2+t^3/3-t^4/4+\cdots} \\
&= \frac{1}{t}\left[\frac{1}{1-\underbrace{\left(\frac{t}{2}-\frac{t^2}{3}+\frac{t^3}{4}+\cdots\right) }_x}\right] \\
&= \frac{1}{t}(1+x+x^2+x^3+\cdots)
\end{align*} Inside the parentheses, the term linear in ##t## only gets a contribution from ##x##. The ##t^2## term has two contributions: the second term of ##x## and the first term of ##x^2##, so you'd have
$$\frac{1}{\log(1+t)} = \frac{1}{t}\left[1+\frac{1}{2} t + \left(-\frac 13 + \frac 14\right) t^2 + \cdots\right]$$ And so on.
Likes fresh_42 and PeroK
[itex]1/\log(1 + t)[/itex] doesn't have a Taylor series about [itex]t = 0[/itex], because the function is not defined (and therefore not differentiable) there: [itex]\log(1 + 0) = \log 1 = 0[/itex]. It does have a Laurent series about [itex]t = 0[/itex].
What is "the natural Taylor expansion"? Is this is typo?
-Dan
FAQ: Taylor series of 1/ln(t+1) at t=0
What is a Taylor series?
A Taylor series is a representation of a function as an infinite sum of terms calculated from the values of its derivatives at a single point. It is expressed in the form of a polynomial, where each term is derived from the function's derivatives evaluated at that point, typically denoted as \( f(a) + f'(a)(x-a) + \frac{f''(a)}{2!}(x-a)^2 + \ldots \).
How do you find the Taylor series of \( \frac{1}{\ln(t+1)} \) at \( t=0 \)?
To find the Taylor series of \( \frac{1}{\ln(t+1)} \) at \( t=0 \), we first need to calculate the derivatives of the function at \( t=0 \). We then evaluate these derivatives at \( t=0 \) and use them to construct the series. The series can be expressed as \( \sum_{n=0}^{\infty} \frac{f^{(n)}(0)}{n!} t^n \), where \( f(t) = \frac{1}{\ln(t+1)} \).
What is the radius of convergence for the Taylor series of \( \frac{1}{\ln(t+1)} \)?
The radius of convergence for the Taylor series can be determined using the ratio test or root test. For the function \( \frac{1}{\ln(t+1)} \), the series converges for \( |t| < 1 \) since \( \ln(t+1) \) approaches zero as \( t \) approaches -1, which causes the function to become undefined.
What are the first few terms of the Taylor series for \( \frac{1}{\ln(t+1)} \) at \( t=0 \)?
The first few terms of the Taylor series for \( \frac{1}{\ln(t+1)} \) at \( t=0 \) can be determined by calculating the derivatives at \( t=0 \). The series starts with \( 1 + t + \frac{t^2}{2} + \frac{t^3}{3} + \ldots \), which can be expressed compactly as \( \sum_{n=0}^{\infty} \frac{t^n}{n} \) for \( |t| < 1 \).
What applications does the Taylor series of \( \frac{1}{\ln(t+1)} \) have?
The Taylor series of \( \frac{1}{\ln(t+1)} \) has applications in various fields such as physics, engineering
