Solving the Taylor Series for e^(-x^2): Is it the Same at x=0?
In summary, the Taylor series of a polynomial about x=a is defined by:\sum_{n=0}^\infty \frac{f^{(n)}(a)(x-a)^n}{n!}
sparkle123
175
Do you just replace the x's with (x-3)'s? Since e^(-x^2) is defined as the taylor series though, it seems like the answer should be the same as the series about x=0.
Thanks!
P.S. does anyone know how to resize images? :$
It's probably easiest just to crank out the first 3 derivatives and use the Taylor series formula.
Thanks, but how would you do that?
The Taylor series of a polynomial about x=a is defined by:
[tex]
[/tex]
I would start by finding the Taylor series for ex about x=3, which will not be the same as the Maclaurin series.
Where exactly are you getting stuck?
Is this right?
Taylor series for e^x about x=3:
e^x+e^x(x-3)+e^x(x-3)^2 / 2 + ... e^x(x-3)^n / n!
=e^3+e^3(x-3)+e^3(x-3)^2 / 2 + ... e^3(x-3)^n / n!
Taylor series for e^(-x^2) about x=3:
e^(-x^2) + e^(-x^2)(x-3) + e^(-x^2)(x-3)^2 /2 + ... e^(-x^2)(x-3)^n / n!
=(e^-9) + (e^-9)(x-3) + (e^-9)(x-3)^2 / 2 + ... + (e^-9)(x-3)^n / n!
Taylor series for int(e^(-x^2)) about x=3:
I don't know how to integrate:
The first series is correct, but the other two aren't.
What's your background in calculus? If you don't know how to integrate and differentiate, you won't be able to do this problem.
D: I'm taking ap calc in 12 days
could you please show me how to do it?
Actually, I misspoke. You really only need to know how to differentiate.
It's against forum policy to give out solutions, but I can tell you you need to know: how to differentiate an exponential, the chain rule, the product rule, and the fundamental theorem of calculus. That'll get you the derivatives. Then you just have to use the formula for the Taylor series, which jhae2.718 has already provided you.
Thanks!
hi,
your first idea is incorrect, you cannot just substitute (x-3) into the series. luckily, your second idea is correct!
no idea about images.
cheers
Related to Solving the Taylor Series for e^(-x^2): Is it the Same at x=0?
1. What is the Taylor series for e^(-x^2)?
The Taylor series for e^(-x^2) is an infinite series representation of the function e^(-x^2) centered at x=0. It can be written as:
e^(-x^2) = 1 - x^2 + (x^4/2!) - (x^6/3!) + (x^8/4!) - ...
2. How do you solve the Taylor series for e^(-x^2)?
The Taylor series for e^(-x^2) can be solved by using the general formula for a Taylor series and plugging in the derivatives of e^(-x^2) at x=0. This results in the infinite series shown in question 1.
3. Is it necessary to use the Taylor series for e^(-x^2) at x=0?
No, the Taylor series for e^(-x^2) can be centered at any value of x. However, using x=0 is often the most convenient choice because it simplifies the calculations.
4. Why is the Taylor series for e^(-x^2) important?
The Taylor series for e^(-x^2) is important because it allows us to approximate the value of e^(-x^2) at any point, not just at whole numbers. This is especially useful in mathematical and scientific calculations that involve the function e^(-x^2).
5. Is the value of e^(-x^2) at x=0 the same as the sum of the Taylor series?
Yes, the value of e^(-x^2) at x=0 is equal to the sum of the Taylor series. However, since the series is infinite, the sum is an approximation of the actual value, which means it will only be equal if all terms are included.
