TE and TM modes in optical fibers
In summary: Yes, a waveguide would be a great place to start. Modes are a set of solutions of linear equations (in this case Maxwell's equations in the waveguide), out of which you can compose all solutions. If you deal with self-adjoint differential operators you get a complete orthonormal set of eigenfunctions of these operators, and all solutions can be written in terms of these functions, which is a generalized Fourier series (or transformation if you have continuous "eigenvalues").In summary, modes are a set of solutions of linear equations, with each solution representing the spectrum of the waveguide. If you have an external field that is propagating in the waveguide, you can describe it as a
EmilyRuck
136
In a step-index optical fiber, considering Bessel functions of order ##\nu = 0## and no ##\phi## dependence, it is possible to obtain two separate sets of components, which generate respectively TE and TM modes. In the former case, only ##E_{\phi}##, ##H_r##, ##H_z## are involved; in the latter, only ##H_{\phi}##, ##E_r##, ##E_z##.
The exact modes in optical fibers are: TE, TM, EH, HE. Also, some approximated modes can be identified, known as LP: each of them may be regarded as the composition of two or more exact modes.
This gives me some confusion: are the exact modes able to propagate alone, or not? Is a single TE mode available for propagation in a step index fiber? A single HE11 mode?
And, if not, how do they propagate, then?
Thank you anyway
Science news on Phys.org
Modes are a set of solutions of linear equations (in this case Maxwell's equations in the fiber), out of which you can compose all solutions. If you deal with self-adjoint differential operators you get a complete orthonormal set of eigenfunctions of these operators, and all solutions can be written in terms of these functions, which is a generalized Fourier series (or transformation if you have continuous "eigenvalues").
EmilyRuck said:
Summary:: Do they propagate alone, or are they only used to compose other modes?
Thank you anyway
Yes- you can launch a single-mode into a fiber and that mode can propagate unchanged. It's also possible to launch a linear superposition of modes into the fiber, and each mode will propagate independently from each other.
Lastly, it's possible to use a fiber as a sensor by examining how the mode amplitudes change to measure external mechanical strain, external electromagnetic fields, etc. In fancy terms, the external potentials act to perturb the mode structure of the fiber- transferring energy from one mode to another. Polarization-maintaining fibers are excellent for this application.
Likes EmilyRuck
Yes, I get it.
Sorry, I don't know them.
If I correctly understood, yes, modes somehow represent the spectrum of the optical fiber. Any real field propagating in this structure can be described as a composition of modes.
But my post was about a slightly different scope: are all these modes individually able to propagate? In particular when dealing with optical fibers, very often, only LP modes are considered; but they are not eigenfunctions, and they are not even real modes, just approximations.
I did not find notes or texts explicitly talking about a single TE or TM mode which is able to propagate alone, hence my doubt.
Ok, thank you so much!
Oh, I don't deal with this, but it is great.
In a step-index optical fiber, considering Bessel functions of order ν=0ν=0\nu = 0 and no ϕϕ\phi dependence, it is possible to obtain two separate sets of components, which generate respectively TE and TM modes. In the former case, only EϕEϕE_{\phi}, HrHrH_r, HzHzH_z are involved; in the latter, only HϕHϕH_{\phi}, ErErE_r, EzEzE_z.
It strikes me that a bit of basic reading about conventional waveguides could help you get into this subject. Waveguides are very often rectangular section (hard to make optical fibres this shape) and the analysis is much more straightforward. Piling in with the necessary Bessel functions for circular guides can be avoided if you start off with rectangular modes first.
Likes Ibix
EmilyRuck said:
Yes, I get it.
Yes they are. Since the equations used to describe the waves are linear each mode propgates independently of any other, i.e., if at some initial time the solution is a particular superposition of modes it stays this superposition at any time.
Note however, that "propagate" must be taken with a grain of salt since not all modes really "propagate" in the literal sense, because there are also "evanescent modes", which die out exponentially.
Likes EmilyRuck and sophiecentaur
Ok! My doubt arouse because of sentences like:
In almost all practical optical fibers one would not find light propagating in the form of TE, TM or HE modes. Light propagates in the form of linearly polarized modes which are briefly called as LP modes. The TE, TM and HE modes thus remain only to academic investigations, because in practice light inside an optical fiber is almost linearly polarized.
from this document, page 6. However, if I correctly understood what you state, TE and TM modes are, at least conceptually, valid and existing modes, and they are able to propagate by their own.
Yes, of course. This depends on the frequency of the input signal. I was implicitly assuming that it is above the cutoff for at least one TE and one TM mode.
Likes vanhees71
Yes, it is not a good starting point. I have read about the dielectric slab, for example, where modes are much simpler and immediate. My problem is not about modes themselves, but about some unclear information on what modes actually propagate in optical fibers (refer to the quote I just posted in the previous message). I wasn't sure if TE and TM modes exist at all, or are able to propagate at all.
that's not what it says on pg6 of that doc
the cluster TE01, TM01 and HE21 degenerate to form one single linearly polarized mode. The dominant mode HE11 is already a linearly polarized mode as can be seen from figure 7.1. In almost all practical optical fibres one would not find light propagating in the form of TE, TM or HE modes. Light propagates in the form of linearly polarized modes which are briefly called as LP modes. The TE, TM and HE modes thus remain only to academic investigations, because in practice light inside an optical fibre is almost linearly polarized.
Related to TE and TM modes in optical fibers
What are TE and TM modes in optical fibers?
TE (Transverse Electric) and TM (Transverse Magnetic) modes are two types of electromagnetic waves that can propagate through an optical fiber. These modes have different electric and magnetic field configurations and are used to transmit light signals through the fiber.
What is the difference between TE and TM modes?
The main difference between TE and TM modes is the orientation of the electric and magnetic fields. In TE modes, the electric field is perpendicular to the direction of propagation, while the magnetic field is parallel to it. In TM modes, the opposite is true, with the magnetic field perpendicular to the direction of propagation and the electric field parallel to it.
How are TE and TM modes generated in optical fibers?
TE and TM modes can be generated in optical fibers through various methods, such as using polarizers, birefringent fibers, or mode converters. These methods manipulate the polarization of the light to produce the desired mode.
What are the applications of TE and TM modes in optical fibers?
TE and TM modes have various applications in optical fibers, including telecommunications, fiber lasers, and fiber sensors. They also play a crucial role in mode-division multiplexing, where multiple modes are used to increase the bandwidth of the fiber.
How do TE and TM modes affect the transmission of light in optical fibers?
The propagation of light in optical fibers is affected by the mode used. TE and TM modes have different propagation characteristics, such as different phase velocities and attenuation rates. This can impact the quality and speed of data transmission through the fiber.
  • Classical Physics
  • Other Physics Topics
