Analysis of TE and TM Modes: A Closer Look
In summary: What happens is that the wave bounces around inside the waveguide but it does so along the direction of guided propagation.
Karthiksrao
68
I'm a little confused about the analysis of TM and TE modes.
As per definition, TE modes have only H (magnetic field) in the direction of propagation and TM mode has only E in the direction of propagation.
But we also know that when an electromagnetic wave propagates in a medium, E and H fields have to be perpendicular to the direction of propagation (unless the medium is anisotropic (?).
So TE and TM modes exist only in anisotropic media ? If not, what am I missing ?
Thanks. Does it mean that it is completely irrelevant to talk about TE and TM modes when the waves are traveling in any other medium (not a waveguide) ? Do these modes exist only when the waves are traveling in a waveguide ?
Good question.
The important property of a metallic waveguide is total internal reflection. EM waves can also be totally internally reflected inside a dielectric when the direction of propagation exceeds a minimum angle θ to the surface (e.g., total internal reflection and critical angle). So a dielectric can support TE and TM modes. Optical fibers are an example.
"Waveguides can be generally classified as either metal waveguides or
dielectric waveguides. Metal waveguides normally take the form of an
enclosed conducting metal pipe. The waves propagating inside the metal
waveguide may be characterized by reflections from the conducting walls.
The dielectric waveguide consists of dielectrics only and employs
reflections from dielectric interfaces to propagate the electromagnetic wave
along the waveguide
See http://www.ece.msstate.edu/~donohoe/ece3323waveguides.pdf
I'm still confused though, is it the total internal reflection that is causing the electric field to have a component along the direction of propagation?
So does it mean when waves are just propagating in any material, without any internal reflection, we just have TEM modes (where both E and H are perpendicular to direction of propagation)?
Yes. Metal and dielectric waveguides are very similar. See http://www.ece.msstate.edu/~donohoe/...waveguides.pdf
Yes, like light going through air, lenses, prisms, etc. where refraction is important.
When they talk about TE and TM modes, often there is an assumed direction of reference. For example, you will often hear about TE and TM modes in reference to waveguides. But the actual waves generally are still TEM modes in terms of the actual direction of the wave's propagation. The TE and TM is taken in reference to the direction of guidance, typically the direction along the length of the waveguide. What happens is that the wave bounces around inside the waveguide but it does so along the direction of guided propagation. So the direction of guided propagation is not necessarily the same as the direction of the wave's actual propagation dicated by the wavevector. You can think of the case of a parallel plate waveguide where the wave bounces in between the two plates, traveling in a net displacement along the plates. If you look at the actual solutions, you will see that it is a superposition of two plane waves reflecting back and forth inside the waveguide. So while the wave is still technically TEM, we talk about it terms of TE_z and TM_z modes in terms of, in this case, the z-direction.
But I believe true TE and TM modes can exist, like in the regions where sources are present or in special confined cases like a surface wave or evanescant modes.
Born2bwire said:
...The TE and TM is taken in reference to the direction of guidance, typically the direction along the length of the waveguide. What happens is that the wave bounces around inside the waveguide but it does so along the direction of guided propagation.
Actually not. TE and TM stand for transverse electric and transverse magnetic, the field that is perpendicular to the plane of reflection at the boundary (e.g., waveguide wall).
In a waveguide, the direction of propagation is generally regarded as being along the axis, TE and TM is referencing to the axial direction, so that they do exist in waveguide. Of course, any field can be decomposed into plane waves, which are TEM waves with respect to their own propagation directions. In spherical geometry, even in free space, the referencing direction is generally the radial direction of the coordinate system, so that TE and TM spherical waves exist. But again, if you decompose them into plane waves, each individual component is still TEM w.r.t. its own wave vector.
sunjin09 said:
In a waveguide, the direction of propagation is generally regarded as being along the axis, TE and TM is referencing to the axial direction...
No. TE and TM refer to the direction orthogonal (transverse) to the axis of the wavegiuide...
EZ=0 ≡ TE mode,
HZ=0 ≡TM mode
EZ=0 ≡ TE mode,
HZ=0 ≡TM mode
This is what both of us previously stated. TE and TM is taken with respect to the direction of guided propagation, which is the axis of the waveguide. This means that the fields are transverse to the direction of guided propagation. This is not what you said in the previous post though. What you said previously,
seems contradictory. It does not make sense to refer to the plane of reflection since, say a rectangulary waveguide has two planes that the waves reflect off of. For the field to be normal to both planes of reflection would require that the only component left must be along the axis of the waveguide.
For the OP, take a look at this set of lecture notes that shows the solution for the rectangular PEC waveguide.
http://www.amanogawa.com/archive/docs/EM15.pdf
The actual field modes look complicated, take a look at slide 272. But as sunjin09 said earlier, you can decompose it into plane waves as seen in the equations on slide 264 (which being the TE mode has no z component to the electric field as z is taken as the direction of guided propagation). The cosine and sine functions can be taken as the superposition of four traveling waves that combine to make two standing waves. Thus,
[tex] \cos(k_xx)\sin(k_yy)e^{ik_zz} = -.25i (e^{-ik_xx} + e^{ik_xx})(e^{-ik_yy} - e^{ik_yy})e^{ik_zz}[/tex]
So one plane wave travels in the [itex]\mathbf{k} = k_x\hat{x}+k_y\hat{y}+k_z\hat{z}[/itex] direction while another travels in the [itex]\mathbf{k} = -k_x\hat{x}+k_y\hat{y}+k_z\hat{z}[/itex] and so forth. The end result though when you combine all the possible waves is that you have a standing wave in the x and y directions while a traveling component in the z direction. But it is possible to only excite the plane waves that make up the solution individually and watch it bounce back and forth traveling in the z direction as illustrated on slide 243. This would be more apparent in a time-domain simulation where we can watch the wave bounce back and forth. The solutions above are time-harmonic and represent the field distributions in all of space that satisfy the boundary conditions.
Take a look at slide 241 inhttp://www.amanogawa.com/archive/docs/EM15.pdf.
The TE mode is defined by the fact that the E vector is perpendicular to the plane of reflection off the wall of the waveguide. It can be either TEm0 or TEon depending on which wall it reflects off of.
This is not very helpful. As already stated, TE (TM) waves are such where the electric (magnetic) field modes are perpendicular to the axis of the wave guide. A special mode is the TEM mode, where both fields are perpendicular to the axis. It can only exist in wave guides with multiply connected cross sections (e.g., coaxial cable).
Honestly, these TE and TM terminologies are somehow arbitrary, they are defined differently. Believe it or not, the FDTD computational EM community calls a TE mode pertaining to the reflection from a half space (E field parallel to the interface) TMZ mode, since they always take the interface as the y-z plane, and look downward from the z-axis, so that a TE mode (as defined in most physics books) with E field in the z direction and H field in the x-y plane (transverse to z), is called "TMZ" ...
The electric field vector on that slide in the TE mode is parallel to the reflecting surface. The red vector denotes the direction of the electric field.
Correct. What I mean is that the E vector is perpendicular to the plane made by the incident wave and the reflected wave, not to the reflecting surface.
FAQ: Analysis of TE and TM Modes: A Closer Look
1. What is the difference between TE and TM modes?
TE (Transverse Electric) and TM (Transverse Magnetic) modes are two types of electromagnetic waves that can propagate through a medium. The main difference between them is their polarization, or the orientation of the electric and magnetic fields. In TE modes, the electric field is perpendicular to the direction of propagation, while in TM modes, the magnetic field is perpendicular to the direction of propagation.
2. How are TE and TM modes used in practical applications?
TE and TM modes are commonly used in the analysis and design of waveguides and optical fibers, which are used in communication systems. They are also utilized in microwave circuit design, radar systems, and other electromagnetic devices.
3. What factors affect the propagation of TE and TM modes?
The propagation of TE and TM modes is affected by the geometry and material properties of the medium in which they are propagating. The frequency and wavelength of the wave, as well as any discontinuities or changes in the medium, can also impact the propagation of these modes.
4. How do TE and TM modes behave at boundaries between different media?
At boundaries between different media, TE and TM modes can experience reflection, transmission, and mode conversion. The amount of reflection and transmission depends on the angle of incidence, the properties of the media, and the polarization of the incident wave.
5. What is the significance of studying TE and TM modes in electromagnetic theory?
Understanding TE and TM modes is essential in the analysis and design of electromagnetic devices, as well as in the study of wave propagation in general. These modes also have practical applications in various fields, such as telecommunications, radar, and optics. Additionally, studying these modes can provide valuable insights into the behavior of electromagnetic waves and their interactions with different media.
14K
