Technology behind the small jump-starters for cars?
In summary, small jump-starters for cars use advanced technology to provide a convenient and portable solution for jump-starting a vehicle. They typically use lithium-ion batteries and microprocessors to deliver a powerful and safe boost of energy to the car's battery. These jump-starters also often come equipped with additional features such as USB ports and LED lights. Overall, the technology behind these small jump-starters allows for a reliable and efficient way to jump-start a car without the need for traditional bulky equipment.
Stephen Tashi
1,599
TL;DR Summary
What's the technology used by the small devices that can jump start cars? Is it batteries? - capacitors?
What's the technology used by the small devices that can jump start cars? Is it batteries? - capacitors? Fuel cells?
Stephen Tashi said:
What's the technology used by the small devices that can jump start cars? Is it capacitors?
Could be capacitors, they seem to be gaining popularity. . . 🤔
Super capacitor jump starter - YouTube
I have seen demos of capacitor based start boosters. They work great if you only need 1-2 seconds of cranking.
If you need 1 minute of cranking, portable boosters with motorcycle size lead acid batteries are good.
If you need 5-10 minutes of cranking (think -40 degrees outside temperature and non-computer carbureted gasoline engines) then a large car/truck battery will barely do it.
Those electric starters are not all they are cranked up to be.
If the engine is big and the weather is really cold you need a pilot engine. That has magneto ignition, started with a pull cord, it then burns maybe half a gallon of fuel while heating and circulating the shared oil and coolant of the main diesel engine. You have time for breakfast, then you engage the clutch to start the main.
Not the sort of thing you drive around the corner to the shop, when you have a bicycle.
I see no future for this newfangled boosted electrickery stuff.
Portable jump starters tend to have AGM/gel batteries inside, but more recent ones, like these: https://no.co/products/power/jumpstarters
...have lithium batteries. They tend to have reverse polarity and anti-spark protection. Reviews vary widely, from the best thing the user has ever bought, to totally useless. The variation may be due in part to the operator. For example, if your problem is a corroded engine Earth strap, and you connect the jump starter directly to the battery, it will suffer the same voltage drop and appear useless.
Mains-powered charger/booster units have the ability to start even large tractor engines on their own.
Stephen Tashi said:
Summary:: What's the technology used by the small devices that can jump start cars? Is it batteries? - capacitors?
I have one using a tiny Lithium battery and it works very well. It is capable of cold starting a 3L Diesel engine, and amazingly, is charged up using a USB socket. It fits into a small glove compartment and can deliver 600 Amps.
Likes dlgoff, anorlunda and davenn
One problem with these emergency jump starters comes with the user :rolleyes: - they forget to keep it charged.
Likes anorlunda and tech99
Related to Technology behind the small jump-starters for cars?
1. How do small jump-starters for cars work?
Small jump-starters for cars work by using a chemical reaction to convert chemical energy into electrical energy. This electrical energy is then used to provide a boost of power to the car's battery, allowing it to start the engine.
2. Are small jump-starters safe to use?
Yes, small jump-starters are generally safe to use as long as they are used correctly. It is important to follow the manufacturer's instructions and safety guidelines to avoid any accidents or damage to the car or the jump-starter itself.
3. How long does it take for a small jump-starter to charge a car battery?
The time it takes for a small jump-starter to charge a car battery can vary depending on the size and capacity of the jump-starter, as well as the condition of the car's battery. On average, it can take anywhere from 10-30 minutes to fully charge a car battery.
4. Can small jump-starters be used for other vehicles besides cars?
Yes, small jump-starters can be used for other vehicles such as motorcycles, boats, and even some larger vehicles like trucks and SUVs. However, it is important to check the manufacturer's guidelines to ensure that the jump-starter is compatible with the specific vehicle.
5. Do small jump-starters require any maintenance?
Yes, small jump-starters may require some maintenance to ensure they are functioning properly. This may include charging the jump-starter regularly, checking the connections and cables, and replacing any damaged parts. It is important to refer to the manufacturer's instructions for specific maintenance guidelines.
  • Electrical Engineering
14K
