Temperature and Compressing Water?
In summary, when a liquid is subjected to a pressure greater than its atmospheric pressure, its temperature may increase, decrease, or stay the same.
ryan albery
67
Does anybody know what happens to the temperature of water when it's subject to a very high pressure? Say you take water at room temperature and apply a pressure of 20MPa, does it get hotter (and thus less dense), colder (more dense), or does it's temperature stay the same?
Science news on Phys.org
The density of a liquid doesn't depend on the temperature in the same way as a gas.
Water in particular is complicated by the bonds rearranging themselves - which is why water has a maximum density at a temperature of 4C (at normal pressure)
Like most liquids water isn't very compressible at 20Mpa (say 2000m) the density only increase by 1% or so
If you compress something you are doing work and (ignoring phase changes) the temperature will rise.
Yeah, intuitively I feel that compressing something (doing work) will increase the temperature, but with water, won't that will make it less dense?
Clarification: if a fluid (gas or liquid) isn't volume constrained, the density does vary roughly linearly with temperature, along a pretty wide range.
That's not what the OP was asking, though. The OP was aksing about applying pressure, which means you must have a closed container. As a result, the temperature goes up as the pressure goes up - again, just like with a gas.
The only real difference in the behavior between a gas and liquid in these scenarios is the coefficients.
Well yes, as it gets close to the point where the phase changes, it starts behaving differently. Outside of that, it can be pretty linear.
If you take an unconstrained volume of water and increase the temperature, the volume will increase roughly linearly with the temperature along most of the temperature range available (3-100C, give or take).
But that's not what you asked in your first post. In your first post, you specified (without realizing it) that the volume was decreasing and then asked if the density (and temperature) was decreasing! If you decrease the volume, obviously you increase the density. At the same time, you've added energy to a compressible fluid, therefore you'll increase the temperature.
Thanks for the suggestions and information. This all makes sense to me for what I'll call 'normal' liquids. I was mainly wondering if the way the molecules fit together to give water it's lowest density around 4C did anything to alter the temperature/pressure/density relationship. I'm still a bit confused, but from what I'm reading I take it that this doesn't really make a difference, and that water is pretty much the same as other liquids when it comes to pressure, temperature, and density.
FAQ: Temperature and Compressing Water?
What happens to water when it is compressed?
When water is compressed, its molecules are pushed closer together, causing its density and pressure to increase. This can also cause its boiling point to increase, resulting in a higher temperature needed for the water to boil.
How does temperature affect water's compressibility?
As temperature increases, water becomes less compressible. This is because at higher temperatures, water molecules have more energy and move around more, making it harder to compress them into a smaller space.
Can water be compressed to a solid form?
Yes, water can be compressed into a solid form under extreme pressures. This is known as "ice VII" and can only occur at pressures above 2.1 GPa and temperatures below 130 degrees Celsius.
What is the relationship between temperature and pressure when compressing water?
As water is compressed, its pressure increases and its temperature also increases. This is because the energy from the compression is converted into heat, causing the water to become hotter.
How does compressing water affect its properties?
Compressing water can change its properties, such as its density, viscosity, and boiling point. It can also cause phase changes, such as liquid water turning into solid ice under high pressures. Additionally, compressing water can affect its ability to dissolve other substances.
