Temperature as a measure of the kinetic energy of molecules
In summary, the conversation discusses the concept of temperature as a measure of kinetic energy in gases, solids, and liquids. It is mentioned that potential energy does not affect temperature in gases due to the large distances between molecules. The textbook definition of temperature is solely based on kinetic energy, but there are instances where potential energy is also referred to as temperature. The relationship between temperature and kinetic energy is discussed, and it is mentioned that the kinetic theory of gases relates pressure and volume to average kinetic energy. The conversation also touches on the history of how temperature was defined and how it is related to the transfer of kinetic energy in the theory of atoms and molecules.
Karol
1,380
I know that temperature is a measure of the kinetic energy of gas molecules. at a given temperature different gases have the same average kinetic energy.
But in solids and liquids there is also potential energy between the close atoms/molecules. how do i know that temperature is here also a measure only of the kinetic energy? maybe it is a measure of part of the potential energy also?
Kinetic energy of different gases at 00C in Jouls:
Hydrogen: 5.6E-21
helium: 5.6E-21
nitrogen: 5.6E-21
Because potential energy is static, it doesn't affect the movement, so we can assume that what happens in gases is the same in metals and liquids
Is this the question you are being asked, or that you are asking?
Karol said:
2. Homework Equations
Hydrogen: 5.6E-21
helium: 5.6E-21
nitrogen: 5.6E-21
And, is this your answer?
I ask if in solids and liquids also the temperature is a measure only of the kinetic energy and not of the potential energy as well.
In gases there is almost no potential energy because of the large distances between the molecules.
I tried to explain my opinion in The attempt at a solution
Yes, but can you fill in a bit more of the argument? Why is it movement that determines temperature? Think about how heat conducts.
I don't know why movement determines temperature, although i (think i) know that molecules from a warm area move faster and hit other molecules near by which deliver forward this fast movement. it's called conduction.
I think the textbook definition of temperature is solely kinetic energy, but there are times when potential energy can be called a "temperature". This is not the same temperature, though. One example where I've seen it used this way is in a setup for optical tweezers. You shine a laser on a molecule, and it moves to the center of the beam (or wherever the high intensity point is). I think the reason this gets called a temperature is because the molecule moves along the potential gradient (which does work), thus actually increasing the kinetic energy of the molecule. The "temperature" function here is essentially the potetential function. Whether or not this is a good way to look at it, I don't know, but it definitely helped to understand how the setup was working.
Yes, but also what happens to the fast moving molecule when it hits slower ones?
Oh, the fast ones, i guess, slow down, so the body cools
Certainly the KE is shared out - until what point? Does that sound like what temperature does?
Until the whole lump has the same KE, and temperature also shares out until all parts have the same temp.
This shows they are direct proportionally related, but it's not yet a proof.
But i have another question. i heard that the kinetic theory of gases relates pressure and volume to average kinetic energy, but has anyone actually measured the velocities of molecules in gas? how do you do that?
How do you think temperature is defined?
It probably depends on what you mean by direct measurement. E.g. you could infer it from Doppler shifts in spectra.
I read from the site hyperphysics and they define temperature as related to kinetic energy.
By direct measurement of velocity of molecules i mean a simpler experiment than a Doppler shift in spectra, a more classical one with less sophisticated equipment and preferably one that was made long ago...
That makes it easy. But temperature was discussed by physicists before the KE connection was known. At that time, it would have been based on the observations that (1) the hotness of a body can be measured in a consistent way by expansion of a liquid, and (2) that objects which measure differently on that scale, placed adjacently, come to be equal. If you define it in those terms, and you have a theory of atoms and molecules as mobile particles, then transfer of KE is a persuasive model.
That would be very challenging even now. You cannot see the molecules, so how direct can that be?
Thanks
Related to Temperature as a measure of the kinetic energy of molecules
1. What is temperature?
Temperature is a measure of the average kinetic energy of the molecules in a substance. It is a measure of how fast the molecules are moving or vibrating.
2. How is temperature related to kinetic energy?
Temperature and kinetic energy are directly proportional. This means that as the temperature increases, the kinetic energy of the molecules also increases. Conversely, as the temperature decreases, so does the kinetic energy.
3. How is temperature measured?
Temperature is typically measured using a thermometer. There are different types of thermometers, such as liquid-filled, digital, and infrared, but they all work by measuring the expansion or contraction of a substance (such as mercury or a metal) in response to temperature changes.
4. What is the unit of temperature?
The most commonly used unit of temperature is the Celsius scale (°C), which is based on the melting and boiling points of water. Another commonly used scale is the Fahrenheit scale (°F). In scientific measurements, the Kelvin scale (K) is used, which is based on absolute zero (the lowest possible temperature).
5. How does temperature affect the properties of a substance?
Temperature has a significant impact on the physical and chemical properties of a substance. As temperature increases, substances can change from solid to liquid to gas, and may also undergo changes in density, solubility, and reactivity. In some cases, extreme temperatures can also cause changes in the molecular structure of a substance.
  • Atomic and Condensed Matter
