Temperature controlling system with peltier battery?
In summary, the conversation discusses the design of a temperature stabilizing system for solar cells, using a 12V Peltier battery and a simple PC fan. The speaker is seeking further help and expresses uncertainty about the effectiveness of using a Peltier battery in reverse for this purpose. They also mention the simplicity of the required electronics, but note that the calculation of heat flow equations may be challenging.
ugi_89
Thread moved from EE to the Homework Help forums. Poster has been admonished to show their work when posting schoolwork questions
Hello everyone!
I have a thesis to design a temperature stabilizing(controlling) system for solar cells.I need to use 12V Peltier battery and a simple pc fan.Any further help is appreciated.
Most forums have rules of engagement for school assignments.
It is also unclear what you are trying to do.
ugi_89 said:
Hello everyone!
Peltier battery? Is that a Peltier cooler in reverse?
If so, how are you going to ensure enough heat flow through the cooler to run a fan? Remember it's the flow of heat that powers the battery. A simple difference in temperature won't do since both sides of the battery will soon be at the same temperature. You need a hot side that stays hot and a cool side that stays cool.
The electronics are simple. The battery. Possibly a temperature sensor/switch. A fan. Use multiple batteries in series or parallel to get the fan's voltage and current.
The hard part will be the heat flow equations. For a non-thesis some simple equations would get you in the ballpark, but properly done these will be difficult.
Related to Temperature controlling system with peltier battery?
1. What is a peltier battery?
A peltier battery is a type of thermoelectric device that can generate a temperature difference using an electrical current. It consists of two ceramic plates with different types of semiconductors sandwiched in between, which creates a temperature gradient when an electrical current is applied.
2. How does a temperature controlling system with peltier battery work?
The temperature controlling system with peltier battery works by using the peltier effect, where an electrical current is used to create a temperature difference between the two ceramic plates. This temperature difference can then be used to either cool or heat an object placed on one of the plates, depending on the direction of the current.
3. What are the advantages of using a peltier battery in a temperature controlling system?
One advantage of using a peltier battery in a temperature controlling system is that it does not require any moving parts, making it more reliable and durable compared to other cooling or heating systems. It is also more compact and energy-efficient, as it does not use any refrigerants or compressors.
4. What are the limitations of a temperature controlling system with peltier battery?
One limitation of a temperature controlling system with peltier battery is that it is not suitable for large-scale cooling or heating applications, as it is more efficient in smaller temperature differences. It is also not as efficient as other cooling or heating systems, such as refrigeration or heating pumps.
5. How can a temperature controlling system with peltier battery be used in scientific research?
A temperature controlling system with peltier battery can be used in scientific research for precise temperature control in experiments or sample storage. It can also be used in environmental chambers to simulate different temperature conditions for testing purposes. Additionally, it can be used in medical research for cooling or heating of biological samples or devices.
  • Electrical Engineering
