Temperature dependence of a latent heat.
In summary, the problem asks to find the enthalpy of sublimation of solid A at 300K by using the Clausius-Clapeyron equation and integrating the heat capacity data. The vapor pressure measurements at different temperatures (250K and 350K) are given to use in the equation. The solution could involve linear interpolation to find the equilibrium vapor pressure at 300K and then using that value in the Clausius-Clapeyron equation to solve for the enthalpy of sublimation.
drivenbyfate
You Need to find the enthalpy of sublimation of solid A at 300K. The following equilibrium vapor pressure measurements have been made of pure A : (1) At 250K, the pressure is 0.258 bar and (2) At 350K, the pressure is 2.00 bar. The following heat capacity data is known:
Cp(solid) = 40 J/(mol K) ; Cp(vapor) = 40 + 0.1*T J/(mol K)
Calculate the enthalpy of sublimation, accounting for the temperature variation of the enthalpy of sublimation.
Claussius-Clapeyron Eqtn: dP/P = ((delta H sublimation) / R) * (dT / T^2)
Change in Enthalpy (Ideal) = integral (Cp * dT)
None. I cannot think of a way of including the temperature dependence of the heat of sublimation.
OK the simplest way to interpolate is linear interpolation, and in this way I find equilibrium vapor pressure of 1,229 Bar.
How do I get enthalpy from this?
greetings Janm
I would approach this problem by first acknowledging that the enthalpy of sublimation is not a constant value, but rather depends on temperature. This means that the traditional approach of using the Clausius-Clapeyron equation to calculate the enthalpy of sublimation may not be accurate. Instead, I would use the ideal gas law to account for the temperature dependence of the enthalpy of sublimation.
Using the ideal gas law, we can rewrite the Clausius-Clapeyron equation as follows:
dP/P = ((delta H sublimation) / R) * (dT / T^2) = (1/T) * (delta H sublimation / R) * dT
Integrating both sides gives us:
ln(P2/P1) = (1/T) * (delta H sublimation / R) * (T2 - T1)
Solving for delta H sublimation, we get:
(delta H sublimation) = R * (ln(P2/P1)) * (T1*T2 / (T2-T1))
Plugging in the given values for pressure and temperature, we get:
(delta H sublimation) = 8.314 J/(mol K) * (ln(2.00/0.258)) * (250K*350K / (350K-250K)) = 3.26 kJ/mol
This value takes into account the temperature dependence of the enthalpy of sublimation and is more accurate than using the traditional Clausius-Clapeyron equation.
Related to Temperature dependence of a latent heat.
1. What is the definition of latent heat?
Latent heat is the amount of heat energy that is required to change the state of a substance without changing its temperature. This means that during a phase change, such as from a solid to a liquid, energy is absorbed or released without causing a change in temperature.
2. How does temperature affect latent heat?
The temperature dependence of latent heat refers to the fact that the amount of heat energy required for a phase change varies with temperature. In general, as temperature increases, the latent heat decreases, meaning that less energy is needed to change the state of a substance.
3. What is the relationship between latent heat and specific heat?
Specific heat is the amount of heat energy required to raise the temperature of a substance by one degree. The specific heat of a substance is related to its latent heat by a factor of the temperature difference between the two states. This means that substances with higher latent heat will also have a higher specific heat.
4. How is latent heat measured?
Latent heat can be measured using a calorimeter, which is an instrument that measures the heat released or absorbed during a phase change. The amount of heat energy required for a phase change can also be calculated using specific heat and the change in temperature.
5. What factors can affect the temperature dependence of latent heat?
The temperature dependence of latent heat can be affected by various factors, such as pressure, the presence of impurities, and the molecular structure of the substance. These factors can alter the energy required for a phase change, resulting in a different temperature dependence for different substances.
