Temperature Dependence of Donor Ionization Energies
In summary, the donor ionization energy is calculated using the hydrogen-like model and modified by the screening between the electron and donor. The temperature dependence of the conduction band's bandwidth may affect the donor ionization energy, especially in materials with deep donors and closer to the degenerate regime. However, this effect is often neglected in many applications. Ongoing research is being done to compute the temperature effect on dopants in semiconductors, with some formulations based on the Debye model for lattice vibrations.
Lacan
Donor ionization energies are calculated via the hydrogen-like model and use the static dielectric constant and effective mass to modify the screening between the electron and the donor. Nice and simple, I get it. But in a material the ionized electron needs to go someplace - presumably the bottom states of the conduction band. Given this, does the temperature dependence of the conduction band's bandwidth affect the donor ionization energy?
If so, I can see how this effect would may be small enough to be ignored when the saturation temperature is low (donor ionization energy is small and the concentration of donors is small), but what about when one is closer to the degenerate regime in a material doped with deep donors? In other words, what if the saturation temperature doesn't occur until, say, 1000K+? Does anyone have any examples of when the donor ionization energy get convoluted with the Varshni equation (if that occurs)?
Thanks!
~Lacan
Regardless of the changes in the band gap, temperature will certainly change the vibrational free energy of the lattice surrounding the dopant which can change the ionization "free" energy. In many applications this change is neglected. But there is still on going research to compute the temperature effect on dopants in semiconductors starting from quantum mechanical considerations. I think you could also find some simple formulations in literature based on Debye model for lattice vibrations.
Related to Temperature Dependence of Donor Ionization Energies
1. What is the temperature dependence of donor ionization energies?
The temperature dependence of donor ionization energies refers to the relationship between the temperature of a material and the energy required to remove an electron from a donor atom within that material. As temperature increases, the energy required for ionization decreases, and vice versa.
2. How does temperature affect the ionization energy of donor atoms?
As the temperature of a material increases, the atoms within it gain more thermal energy, causing them to vibrate and move more. This increased motion makes it easier for electrons to break free from donor atoms, resulting in a decrease in ionization energy.
3. Why is it important to study the temperature dependence of donor ionization energies?
Understanding the temperature dependence of donor ionization energies is crucial for many technological applications, such as in the development of semiconductor devices. It also provides insight into the fundamental properties of materials and their behavior at different temperatures.
4. Are there any materials that exhibit a unique temperature dependence of donor ionization energies?
Yes, some materials, such as silicon and germanium, have a specific temperature dependence known as the "bandgap shrinkage" effect. This means that as temperature increases, the bandgap (the energy range where no electron states can exist) decreases, resulting in a decrease in ionization energy.
5. How is the temperature dependence of donor ionization energies measured?
The temperature dependence of donor ionization energies can be measured using various techniques, such as Hall effect measurements or capacitance-voltage measurements. These methods involve applying a voltage or magnetic field to a sample and measuring the resulting changes in its electrical properties at different temperatures.
  • Atomic and Condensed Matter
12K
17K
