Temperature dependence on intrinsic carrier concentration
In summary, the intrinsic carrier concentration Ni for silicon can be calculated using the equation ni^2 = Nc*Nv exp(-Eg/kT) where Nc and Nv are effective density of states values. The energy band gap Eg can be determined experimentally and has a weak dependence on temperature. According to Aschrcoft and Mermin, the band gap for silicon at 0K is 1.17 eV and at 300K is 1.12 eV. However, there is no specific equation for calculating the band gap energy, as it is a property of the material and depends on its structure. The band gap can be measured through its optical properties, where an increase in the absorption coefficient occurs when
elimenohpee
67
How does one calculate the intrinsic carrier concentration Ni for silicon as a function of temperature? I know the equation ni^2 = Nc*Nv exp(-Eg/kT) can be used, but then another equation is needed to find the energy band gap Eg. The effective density of states values Nc and Nv are well defined, but I can't seem to find out how to calculate Eg.
The band (or energy) gap, Eg, for silicon is taken from experiment and is about 1.1-1.2 eV and is known to within 5%. It only has a relatively weak dependence upon temperature.
According to Aschrcoft and Mermin (Solid State Physics, Saunders Coolege Publishing, ):
Eg (0K) = 1.17 eV, Eg(300K) = 1.12 eV.
The band gap can be measured in several ways, eg by its optical properties. When the frequency of an incident photon becomes large enough to excite electrons across the energy gap there is an abrupt increase in the absorption coefficient of the incident radiation.
So basically there is no real "equation" that can be used to specifically calculate bandgap energy? It looks as if Ni isn't susceptible to much change when temperature drops, but I was more interested when temperature increases, which theoretically should shrink the gap. I just need a precise way to calculate by how much.
The band gaps are properties of the material and ultimately relatedto its structure.
According to Pierret ("Advanced Semiconductor Fundamentals", Prentice Hall 2003, see pp 82-83) the manner that the band gap for a large number of semiconductors varies with T can be modeled by the empirical relationship
Eg(T) = Eg(0) - alpha*T^2/(T + beta)
where alpha and beta are constants chosen to obtain the best fit to the experimental data. For silicon Pierret gives
Eg(300 K) = 1.125 eV, Eg(0) = 1.170 eV, alpha = 4.730X10^(-4) eV/K, beta = 636 K.
(Please check before using.)
Related to Temperature dependence on intrinsic carrier concentration
1. What is intrinsic carrier concentration?
Intrinsic carrier concentration refers to the number of free electrons and holes present in a material at thermal equilibrium, without the presence of impurities or external energy sources. It is a characteristic property of a material and is dependent on temperature.
2. How does temperature affect intrinsic carrier concentration?
As temperature increases, the intrinsic carrier concentration also increases. This is due to the fact that at higher temperatures, more thermal energy is available to promote electrons from the valence band to the conduction band, resulting in an increase in the number of free carriers.
3. What is the relationship between intrinsic carrier concentration and band gap energy?
The intrinsic carrier concentration is inversely proportional to the band gap energy. This means that as the band gap energy increases, the intrinsic carrier concentration decreases, and vice versa. This relationship is described by the Arrehenius equation.
4. How is the intrinsic carrier concentration calculated?
The intrinsic carrier concentration can be calculated using the Arrehenius equation, which takes into account the band gap energy, temperature, and effective mass of the charge carriers. This equation is based on the concept of the energy distribution of carriers in a material at thermal equilibrium.
5. What is the significance of understanding temperature dependence on intrinsic carrier concentration?
Understanding the temperature dependence on intrinsic carrier concentration is crucial in the design and optimization of electronic devices, as it affects their performance and efficiency. It is also important in the study of semiconductor materials and their properties, as well as in the development of new materials for various applications.
