Temperature dependent heat-conductivity
  • Thread starter Selveste
  • Tags
    Temperature
In summary, the problem involves a cylinder with length L, inner diameter R1, and outer diameter R2, with temperatures T1 and T2 on the inner and outer surfaces respectively. The heat conductivity k is temperature dependent and given by k = aT^v. Using Fourier's law and the temperature gradient, we can calculate the heat flow and integrate to find T(r). By setting r = R2, we can find the heat flow and solve for T(r).
Selveste
A cylinder has length [itex] L [/itex], inner diameter [itex] R_1 [/itex] and outer diameter [itex] R_2 [/itex]. The temperature on the inner cylinder surface is [itex] T_1 [/itex] and on the outer cylinder surface [itex] T_2 [/itex]. There is no temperature variation along the cylinders lenght-axis. Assume that the heat conductivity [itex] k [/itex] is temperature dependent and given by
[tex] k = aT^{\nu} [/tex]
where [itex] a [/itex] is a constant. Find [itex] T(r), r > 0 [/itex].
Fourier's law
[tex] \boldsymbol{j} = -k \nabla T [/tex]
Temperature gradient
[tex] \nabla T = \frac{dT}{dr} \hat{e_r} [/tex]
where [itex] \hat{e_r} [/itex] is a unit vector in radial direction.
The stationary heat flow outwards is
[tex] \dot{Q} = -k\frac{dT}{dr}2\pi rL [/tex]
rearranges to
[tex] dT = -\frac{\dot{Q}}{2\pi kL}\frac{dr}{r} [/tex]
integration from [itex] r_1 [/itex] to [itex] r [/itex] gives
[tex] T - T_1 = ? [/tex]
Not sure what to do here when [itex] k [/itex] is not constant.
[tex] k(T)dT = -\frac{\dot{Q}}{2\pi L}\frac{dr}{r} [/tex]
Thank you. So integrating
[tex] aT^{\nu}dT = -\frac{\dot{Q}}{2\pi L}\frac{dr}{r} [/tex]
from [itex] r_1 [/itex] to [itex] r [/itex] I find
[tex] \frac{a}{\nu +1}\left(T^{\nu +1} - T_1^{\nu +1}\right) = -\frac{\dot{Q}}{2\pi L}\left(\ln r - \ln r_1\right) \tag{1}[/tex]
which by setting [itex] r = r_2 [/itex] gives the heat flow
[tex] \dot{Q} = \frac{2\pi aL}{(\nu +1)(\ln r_1 - \ln r_2)}\left(T_2 - T_1\right)^{\nu +1}\tag{2} [/tex]
is this correct? And how would I now proceed to find [itex] T(r) [/itex]? Thank you.
is this correct?
Yes, but I would write ##\ln r - \ln r_1=\ln{(r/r_1)}##. And I would correct the exponents on the T's in Eqn. 2.
Just eliminate ##\dot{Q}## between Eqns. 1 and 2.
Likes Selveste
Related to Temperature dependent heat-conductivity
What is temperature dependent heat-conductivity?
Temperature dependent heat-conductivity is a physical property that describes the ability of a material to conduct heat at different temperatures.
How does temperature affect heat-conductivity?
As temperature increases, heat energy is transferred more rapidly, resulting in an increase in the material's heat-conductivity. Likewise, as temperature decreases, heat energy is transferred more slowly, resulting in a decrease in heat-conductivity.
What is the relationship between heat-conductivity and temperature?
The relationship between heat-conductivity and temperature is directly proportional. This means that as temperature increases, heat-conductivity also increases, and as temperature decreases, heat-conductivity decreases.
What factors can affect temperature dependent heat-conductivity?
Some factors that can affect temperature dependent heat-conductivity include the type of material, its physical state (solid, liquid, or gas), and any impurities or imperfections in the material's structure.
Why is understanding temperature dependent heat-conductivity important?
Understanding temperature dependent heat-conductivity is important in several scientific fields, such as thermodynamics, materials science, and engineering. It can also be useful in practical applications, such as designing efficient insulation materials and understanding heat transfer in various systems.
