Temperature gradient vs thermal boundary layer thickness
In summary, the thermal boundary layer is a region near a surface where the temperature varies rapidly from the wall temperature to the temperature at the edge of the boundary layer. The temperature gradient is largest at the wall and decreases rapidly with distance, following a parabolic shape. As the boundary layer thickness increases, the magnitude of the temperature gradient at the wall decreases. The thickness of the boundary layer increases as we move downstream on a flat plate due to the diffusion of momentum and heat from the wall. Eventually, the thermal boundary layer reaches equilibrium as the system becomes isothermal or the heat transfer rate decreases to a negligible amount.
Idrees Afridi
what does the relation between the temperature gradient inside the thermal boundary and thermal boundary layer thickness i mean what will be the temperature gradient ( high or low) when the thermal boundary layer is thick relative to the thin one? Kindly explain mathematically and physically as well...
Thanks
Science news on Phys.org
The boundary layer thickness is usually not a very precisely defined quantity. In typical problems involving boundary layers, the thickness of the boundary layer is envisioned as being small compared to the characteristic physical dimensions of the system. The temperature is envisioned as varying very rapidly from the value at the wall to the value at the "edge of the boundary layer." The temperature gradient is largest at the wall, and decreases rapidly with distance to a very low value at the "edge of the boundary layer." Suppose you approximated that temperature profile in the boundary layer by a parabolic shape, $$T=(T_w-T_{\infty})\left(1-\frac{y}{\delta}\right)^2+T_{\infty}$$where ##T_w## is the wall temperature, ##T_{\infty}## is the temperature at the edge of the boundary layer, y is the distance from the wall, and ##\delta## is the boundary layer thickness. Then from this equation, the temperature gradient would be given by:$$\frac{\partial T}{\partial y}=-\frac{(T_w-T_{\infty}}{\delta}\left(1-\frac{y}{\delta}\right)$$In this approximation, the temperature gradient at the wall would be equal to ##-(T_w-T_{\infty})/\delta## and the temperature gradient at the edge of the boundary layer would be zero. So, if the boundary layer is very thin, the magnitude of the temperature gradient at the wall is very large, and if the boundary layer is thicker, the magnitude of the temperature gradient at the wall is less.
Likes Yada Nandukumar
I got the point. thanks alot
currently i am working on momentum and thermal boundary layer so i have few more questions..
i): why the shape of thermal and velocity boundary layer is parabolic?
ii):why the thickness of these boundary layers increasing as we move from the leading edge of the flat plate?
iii):why the thermal boundary layer is not continuously growing although heat continuously diffuses into this layer?
It isn't.
Viscosity is basically the coefficient of diffusion pertaining to momentum transport, so as you move downstream on a flat plate (without any other influences like changes in pressure gradient) it's akin to moving later in time in a typical diffusion problem. The zero-momentum effect of the wall has simply diffused further into the free stream.
In theory it could be. It just likely reaches a point where it grows very slowly as the system reaches equilibrium.
This is only an approximation that is used sometimes.
The momentum and heat effect of the wall is penetrating more deeply into the fluid as it moves along the wall.
As boneh3ad said, the thermal boundary layer does get thicker in the case of a flat plate.
boneh3ad said:
It isn't.
thanx to guide me but i must ask one thing more that what type of equilibrium u mean ? does it make sense physically ? if yes then how?
I am not sure exactly what you are asking here. Of course it makes sense physically, or it wouldn't happen. Really, there are a few possibilities. If the surface is allowed to change temperature so that the system eventually reaches thermal equilibrium, then eventually heat will stop being transferred between the fluid and the surface and the thermal boundary layer will cease to exist as a concept since everything will be isothermal. That's a rather boring case, though.
Another possibility is that the surface is held at a constant temperature, and in that case the thermal boundary layer will always grow, but at an increasingly slow rate. As the fluid near the wall gets continually hotter (or colder as the case may be), it is nearer and nearer in temperature to the surface, so all of the temperature gradients decrease and the heat transfer rate decreases. With an infinite fluid, the growth will never truly stop, but growth rate will get so incredibly small that it doesn't really matter anyway.
Likes Ravi Singh choudhary
thanks a lot .i got my point ,, stay blessed
Related to Temperature gradient vs thermal boundary layer thickness
1. What is a temperature gradient?
A temperature gradient is the rate of change of temperature with respect to distance. It measures how much the temperature changes over a given distance or space.
2. How is temperature gradient related to thermal boundary layer thickness?
A temperature gradient is directly related to thermal boundary layer thickness. As the temperature gradient increases, the thermal boundary layer thickness also increases. This is because a steeper temperature gradient means there is a greater difference in temperature between two points, resulting in a thicker thermal boundary layer.
3. What is a thermal boundary layer?
A thermal boundary layer is the thin layer of fluid near a solid surface where the temperature changes rapidly due to the transfer of heat between the surface and the fluid. It is a region of turbulent flow where the temperature gradient is steep.
4. How is thermal boundary layer thickness measured?
Thermal boundary layer thickness can be measured using various techniques, such as hot-wire anemometry, thermocouples, or infrared cameras. These methods measure the temperature gradient and determine the point at which the temperature has changed significantly from the surface temperature.
5. Why is understanding temperature gradient and thermal boundary layer thickness important?
Understanding temperature gradient and thermal boundary layer thickness is essential in many fields, such as fluid dynamics, meteorology, and engineering. It helps in predicting heat transfer, energy transfer, and flow patterns in various systems, such as pipes, heat exchangers, and weather patterns. It also plays a crucial role in designing efficient thermal systems and optimizing their performance.
  • Mechanical Engineering
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
