Temperature/heat transfer in space
  • Thread starter poont2
  • Tags
    Space
In summary: Radiation would be the main source of heat transfer from the sun to the body. And from the body to the surrounding space. Assuming there is no other heat transferpaths, the radiation would be the only source of heat transfer.
poont2
Hello PF,
I was wondering how cold would it be for a human to be in space without any suit or insultation. Assume that human have a oxygen tank, so don't worry about suffocation. What are the main factor? Since there are close to no matter in space, we can ignore convection and conduction. We radiate into space, but at the same time the sun is radiating at us. So how cold would it be if we are naked in space comparing to like the coldest place on Earth and why?
Thank you
Science news on Phys.org
From wikipedia on Space Suit:
The human body can briefly survive the hard vacuum of space unprotected, despite contrary depictions in much popular science fiction. Human flesh expands to about twice its size in such conditions, giving the visual effect of a body builder rather than an overfilled balloon. Consciousness is retained for up to 15 seconds as the effects of oxygen starvation set in. No snap freeze effect occurs because all heat must be lost through thermal radiation or the evaporation of liquids, and the blood does not boil because it remains pressurized within the body. The greatest danger is in attempting to hold one's breath before exposure, as the subsequent explosive decompression can damage the lungs. These effects have been confirmed through various accidents (including in very high altitude conditions, outer space and training vacuum chambers). Human skin does not need to be protected from vacuum and is gas-tight by itself. Instead it only needs to be mechanically compressed to retain its normal shape. This can be accomplished with a tight-fitting elastic body suit and a helmet for containing breathing gases, known as a Space activity suit.
Human flesh expands to about twice its size in such conditions, giving the visual effect of a body builder rather than an overfilled balloon . . .This can be accomplished with a tight-fitting elastic body suit and a helmet for containing breathing gases, known as a Space activity suit.
thx for the reply ,
Twice in size, that's very interesting. I thought we would die really quickly if we expand twice in size in such quick time.
For the SpaceSuit, does it mean that the suit has to be very strong to keep the original shape in close to vacuum space ? And since the suit is kept in original shape , it keep the pressure inside so the human doesn't expand?
Im still interesting in the heat transfer side
poont2 said:
thx for the reply ,
It needs to be fairly strong, but I wouldn't say very strong. Probably somwhere around half of atmospheric pressure or so. But that's just a guess. Yea, the space suit applies pressure on the body to keep it from bloating.
So what about the heat transfer side of the question? ignore all other effect,assuming that the main souce of heat transfer are radiation from sun to body and radiation from body to surround, using the equation of radiation.
using this equation
from sun to body
A, Area is limited to the body frontal area and t
T, the temp of the sun is around 5800k,
Tc, body temp
from the body to surround
A, Wouldnt the Area of the surround be infinite?
T, temp of body
Tc, what is the temperature of the surrounding? close to 0 k?
this is the part I am not understanding, i know that there are other start and planet too, but i would the main souce of radiation from the sun? and Wouldnt the Area of the surround be infinite? and what is the temperature of the surrounding? close to 0 k? wouldn't this make the radiation power infinite? what am i missing here?
You would still use the area of the body. The radiation emitted depends on the surface area of the emitting body.
my mistake, so even if i use the surface area of the emitting body. And only a very small percentage of heat from the sun get to the human body because sphere radiate in every direction. Can human body radiate into empty space, or one can only radiate into another matter? if so So how could one explain how cold would it be in space for a human being without any insulation? So exactly around how cold is it?
You have 2 different effects here. Absorbtion, and emission. Both depend on the surface area. But absorbtion also has to include the incoming intensity of the light. The human body would emit radiation into space and lose heat, but not really that much. I'm not sure what you would feel other than the swelling of your skin lol. I would expect that being in sunlight would cause an increase in temp.
using this equation
from sun to body
Tc, body temp
T, temp of body
4k i think
edit - er... 3 i mean
I would suggest the official NASA view (http://imagine.gsfc.nasa.gov/docs/ask_astro/answers/970603.html) is probably correct given the two references they cite are actual experiments on chimpanzees not a best guess scenario.
You could look up the refereneces.
References:
The Effect on the Chimpanzee of Rapid Decompression to a Near Vacuum, Alfred G. Koestler ed., NASA CR-329 (Nov. 1965)
Experimental Animal Decompression to a Near Vacuum Environment, R.W. Bancroft, J.E. Dunn, eds, Report SAM-TR-65-48 (June 1965), USAF School of Aerospace Medicine, Brooks AFB, Texas.
FAQ: Temperature/heat transfer in space
What is the temperature in outer space?
The temperature in outer space is not constant and can vary greatly depending on the location. In the vacuum of space, there is no medium for heat to transfer, so objects can only lose heat through radiation. This means that areas exposed to direct sunlight can reach temperatures of over 100 degrees Celsius, while areas in the shadow of an object can drop to below -100 degrees Celsius.
How does heat transfer in space?
Heat can only transfer in space through radiation, which is the process of energy being emitted in the form of electromagnetic waves. This means that objects in space can only lose heat through radiation and cannot gain or lose heat through conduction or convection.
Can objects get colder in space?
Yes, objects can get colder in space. As mentioned before, in areas where there is no direct sunlight, objects can lose heat through radiation and reach extremely low temperatures. This is why spacecrafts and satellites need special insulation to protect them from extreme temperature changes in space.
Is there a limit to how hot or cold an object can get in space?
There is no limit to how hot or cold an object can get in space. Without the presence of a medium, such as air or water, to regulate the temperature, objects can continue to heat up or cool down indefinitely. However, at extremely high temperatures, objects can begin to emit energy at a faster rate, which can help balance out the temperature.
How does temperature affect space exploration?
Temperature plays a crucial role in space exploration as it can impact the performance and functionality of equipment and spacecraft. Extreme temperature changes can cause damage to sensitive instruments and electronics, so engineers must design spacecrafts to withstand a wide range of temperatures. Temperature also affects the human body in space, so astronauts must have specialized gear and habitats to maintain a comfortable and safe temperature while in space.
