igowithit
- 6
- 1
Edit: Thanks to gneill for showing me the LaTeX ropes. Equations should work now.
A perfect gas enclosed within a container escapes into vacuum through a small circular hole. The particle flux through the hole is ##\frac{nc}{4}## and the energy per particle escaping can be found to be 2kT. Assuming that the volume of the container is fixed, find an expression for the temperature inside the box starting with an initial temperature of ##T_o##.
$$J_n = \frac{nc}{4}$$
$$E_{avg} = \frac{3}{2}kT$$
$$E_{esc} = 2kT$$
$$R_{eff} = \frac{PA}{\sqrt{2\pi MRT}}$$
Temperature is simply an average of the kinetic energy of all the particles. So before any particles escape, the average kinetic energy in the box is
$$E_{0} = \frac{3}{2}kT_o$$
The average kinetic energy will drop by the rate of effusion times the average kinetic energy of the escaping particles, or
$$KE_{box} = \frac{3}{2}kT_o - \frac{PA}{\sqrt{2\pi MRT_o}}*2kT_o$$
I don't think this is quite right though. It needs an integration somewhere from ##T_o## to 0? Any nudges in the right direction are appreciated.
