songoku
- 2,328
- 335
A brass bar and a steel bar, each 0.8 m long are at a temperature of 20oC. Each bar is placed at that temperature between rigid walls 0.8 m apart. The cross - sectional areas for the brass and steel bars are 0.005 m2 and 0.003 m2, respectively. The coefficient of linear expansion and Young modulus of the two materials are given in previous page. The temperature is raised until the combined force exerted by the two bars is 1.8 MN. The temperature at which this occurs, in oC is closest to
a. 100
b. 110
c. 120
d. 130
e. 140
P = F/A
Young Modulus = stress / strain
stress = force / area
strain = extension / original length
ΔL = α . Lo . ΔT
I am not sure I understand the set - up explained by the question. I imagine the two bars are placed parallel to each other between rigid walls. Is this correct?
Then the two bars are heated so they expand and push the walls, creating force. The total force of 1.8 MN is force by brass + force by steel.
If the bars are heated to same final temperature, the extension of each bar will be different even though they are placed between rigid walls. Is this possible?
Thanks
