A Temperature of HII Gas: Intuitive Explanation
  • A
  • Thread starter Thread starter zviz
    Gas Temperature
The temperature of HII gas is typically around 10^4 K, as indicated by Draine's book and supported by the Saha equation for hydrogen. A naive estimate using kT equal to the ionization energy of hydrogen suggests a temperature greater than 10^5 K, leading to a significant discrepancy. This difference arises because ionization is primarily a photoionization process driven by radiation from hot stars, rather than a purely thermal process. Additionally, HII regions cool through radiative decay of metastable states of ions, which contributes to the lower observed temperatures. Understanding these mechanisms clarifies why the actual temperature of ionized hydrogen gas is much lower than the naive estimate.
zviz
I have a question about the temperature of HII gas. According to Table 1.3 in Draine's book (physics of the interstellar and intergalactic medium) this temperature is T~10^4 K.
I get a similar value by using the Saha equation for a hydrogen gas.
However, a naive estimate of the same temperature could be obtained by demanding k*T = 13.6eV, and this would give T>10^5K.
My question is what produces this discrepancy? I am looking for an intuitive answer, if possible, of why the estimate using kT=ionization energy is higher by more than an order of magnitude from the actual temperature where most of the hydrogen gas becomes ionized.
Astronomy news on Phys.org
The intuitive answer is that ion+electron is a state which, at a low density, has far bigger probability and entropy than the state where electron is bound to the ion. Or looking at the process side, atom can be ionized at any time because the electron and ion are together, whereas recombination requires the ion and electron to find one another.
Therefore, at kT=ionization energy, only the tiny fraction corresponding to the tiny volume fraction actually taken up by ions is not ionized. In order to recombine most of the ions, you need to lower the temperature by an order of magnitude till the exponential component outweighs the density component.
The discrepancy is the result of thinking that the ionization process is thermal. It is not.
The ionization process is photoionization. The HI is ionized by interaction with the radiation field of one or more hot stars--type O for example-- typically embedded within the gas cloud. The kinetic energy of the resultant free electrons that determines the temperature is given by the difference between the energy of the ionizing photon and the ionization potential of HI.
You have also not taken account of cooling mechanisms. HII regions are effectively cooled by radiative decay of the collisionally excited, low lying metastable states of ions such as OII, OIII, NII, and SII. The relevant transitions, which are within the visible spectral domain, are electric-dipole forbidden. However, the lifetimes of those metastable states are such that radiative decay via electric-quagrupole or magnetic-dipole allowed transitions is fast relative to collisional decay channels. Being forbidden transitions, the emitted photons are not reabsorbed by the material within the HII region allowing energy loss.
References:
1. E. J. Chaisson, "Gaseous Nebula and Their Interstellar Environment" (Chapter 7) in Frontiers of Astrophysics, E. H. Avrett, Ed., Harvard University Press 1976.
2. D. E. Osterbrock and G. J. Ferland, Astrophysics of Gaseous Nebulae and Active Galactic Nuclei 2nd Ed., University Science Books 2006
First, an editorial correction to Reference 2 above. The correct title of the book by Osterbrock and Ferland is Astrophysics of Gaseous Nebulae and Active Galactic Nuclei.
[Mentor Note -- update made to Reference 2 in above post]
Second, it may be of interest to point out a pragmatic aspect of the electric-dipole forbidden transitions associated with the metastable states of OIII and NII. Both species emit within the visible spectral domain: OIII at 436.3, 495.9, and 500.7 nm; NII at 575.5, 654.8, and 658.3 nm. Those are rest-frame wavelengths. Those spectral lines can be very prominent in the observed spectra of HII regions.
Assuming effective local thermodynamic equilibrium, a free electron density that is sufficiently low to preclude collisional decay of the metastable states, and further assuming that the metastable states are not populated by radiative decay from higher excited states, the ratios of the line amplitudes provides a direct, observable measure of the nebular electron temperature.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
