Temperature of ideal gas in a cylinder
In summary: Yes, heat will flow from higher temperature region to lower temperature region. It would be more precise to say that the system and its surroundings reach an equilibrium temperature, which may or may not be the original room temperature.
Boomzxc
25
Qn : https://www.dropbox.com/s/dpcws9q4bjpzvtp/20151123_112037.jpg?dl=0
Why is option A and C wrong or correct?
My attempted answer :
A :A is plausible as if the piston is suddenly moved inwards, the gas molecules bounce off the piston at higher speeds
Since Temp proportional to rms speed, temp increases
Or
based on 1st law of thermodynamics
The piston suddenly moved in... So means Q=0 cos no time for heat transfer.
Since compression, W is +ve so U is +ve. That implies T increases.
C : as P increases, V decreases
Please help to correct my understanding! !
Thanks a million! !
"Suddenly moves inwards" in the question implies that there was little or no heat exchange during this compression process. With this information, apply the First Law and try and deduce for yourself whether A or C is the correct answer.
Likes Boomzxc
What if the piston is slowly moved inwards? How will the answer change?
If the piston is moved slowly enough, the temperature will not change. Can you rationalize why?
Likes Boomzxc
Is it because there's time for heat distribution throughout the gas??
There's sufficient time during the process for heat to enter or leave the system.
Likes Boomzxc
If the piston is suddenly moved inwards and the temp increased, and i leave the system there for some time, will the system return to it's prior temperature (room temp) assuming this is carried out at room temp?
Yes, heat will flow from higher temperature region to lower temperature region. It would be more precise to say that the system and its surroundings reach an equilibrium temperature, which may or may not be the original room temperature. (before the compression)
Likes Boomzxc
Related to Temperature of ideal gas in a cylinder
1. What is the ideal gas law and how does it relate to the temperature of a gas in a cylinder?
The ideal gas law is a mathematical equation that describes the relationship between pressure, volume, and temperature of an ideal gas. It states that the pressure of a gas is directly proportional to its temperature and the number of moles of gas present, and inversely proportional to its volume. This means that as the temperature of a gas in a cylinder increases, its pressure will also increase.
2. How is temperature measured in a gas cylinder?
Temperature in a gas cylinder is typically measured using a thermometer. This can be done by inserting the thermometer into the gas cylinder or by using a probe attached to the cylinder. Other methods, such as using a thermocouple or infrared thermometer, may also be used to measure the temperature of a gas in a cylinder.
3. Can the temperature of an ideal gas in a cylinder be controlled?
Yes, the temperature of an ideal gas in a cylinder can be controlled by adjusting the pressure and volume of the gas. This can be achieved by changing the amount of gas in the cylinder, or by adjusting the temperature of the surrounding environment. In industrial settings, specialized equipment such as heaters or coolers may be used to control the temperature of gases in cylinders.
4. How do changes in temperature affect the behavior of an ideal gas in a cylinder?
Changes in temperature can significantly impact the behavior of an ideal gas in a cylinder. As the temperature of the gas increases, the molecules within the gas will have more energy and will move faster, resulting in an increase in pressure. On the other hand, as the temperature decreases, the molecules will have less energy and will move slower, resulting in a decrease in pressure.
5. What happens to the temperature of an ideal gas in a cylinder when it is compressed or expanded?
When an ideal gas in a cylinder is compressed, the temperature of the gas will increase due to the increase in pressure. This is because the gas molecules are forced closer together, resulting in more collisions and an increase in kinetic energy. Similarly, when an ideal gas in a cylinder is expanded, the temperature of the gas will decrease due to the decrease in pressure. This is because the gas molecules are allowed to spread out, resulting in fewer collisions and a decrease in kinetic energy.
10K
