Temperature of Space: Atomic/Molecular Motion & Equilibria
In summary: Are they the temperature of the actual ground surface layer in equilibium with solar radiation? That is, the gound surface layer absobs solar radiation and is heated but also loses heat through radiation back to space and conduction to lower layers. Eventually an equilibrium is reached. So what does this mean for the temperature of the moon?The temperatures refer to the temperature of the lunar surface. What does it mean for the temperature of the moon if the ground layer doesn't absorb solar radiation?The surface of the moon doesn't have an atmosphere, so it would be very cold.
Frank Peters
28
Temperature is atomic/molecular motion.
However, the temperature of planetary surfaces without an atmosphere are often quoted. For example, the temperature of the lunar surface ranges from about -200 F to +200 F depending on whether or not the surface is exposed to the sun or is in shadow.
But the moon has no atmosphere so then to what do these temperatures refer?
Are they the temperature of the actual ground surface layer in equilibium with solar radiation? That is, the gound surface layer absobs solar radiation and is heated but also loses heat through radiation back to space and conduction to lower layers. Eventually an equilibrium is reached. Is this the lunar temperature in daylight?
Also, putting quantum theories of the vacuum aside, can we talk about the temperature of interplanetary space? Or can we only describe a similar equilibrium phenomenon when a spacecraft is traveling through interplanetary space?
It would seem to me that interstellar space would be close to an infinite heat sink, as any object within it would radiate away all heat. Yet the voyager probes are still functioning.
Science news on Phys.org
"Empty" space is filled with the Cosmic Microwave Background radiation (CMB), which has a temperature of 2.7K. So an object in interstellar space shielded from any stellar radiation should come into equilibrium with this radiation.
The Voyager probes have their own onboard energy sources. These are Radioisotope Thermoelectric Generators. (RTGs). This heat keeps the probes warm enough so that they are still functioning. They are still generating significant power. This is what Wikipedia has to say on that:
"One example is the RTG used by the Voyager probes. In the year 2000, 23 years after production, the radioactive material inside the RTG had decreased in power by 16.6%, i.e. providing 83.4% of its initial output; starting with a capacity of 470 W, after this length of time it would have a capacity of only 392 W. A related loss of power in the Voyager RTGs is the degrading properties of the bi-metallic thermocouples used to convert thermal energy into electrical energy; the RTGs were working at about 67% of their total original capacity instead of the expected 83.4%. By the beginning of 2001, the power generated by the Voyager RTGs had dropped to 315 W for Voyager 1 and to 319 W for Voyager 2."
It sounds like you think that it takes gas or liquid to have motion.
Solids have temperatures too. You only need to touch a hot stove or a block of ice to know that.
The thermal motion of a solid's molecules can be compared to vibrations.
Frank Peters said:
However, the temperature of planetary surfaces...
Your premise is the answer to your question!
What does that have to do with your question?
Likes sophiecentaur
Related to Temperature of Space: Atomic/Molecular Motion & Equilibria
1. What is the temperature of space?
The temperature of space can vary greatly depending on location, but on average it is around 2.7 Kelvin (-270.45 degrees Celsius or -454.81 degrees Fahrenheit). This is known as the cosmic microwave background temperature, which is the remnant radiation from the Big Bang.
2. Does space have a temperature at all?
Yes, even though space is mostly a vacuum, it still has a temperature due to the presence of radiation and particles. However, this temperature is not the same as the temperature we experience on Earth, as it is affected by factors such as solar radiation and the density of matter in a particular area.
3. How is the temperature of space measured?
The temperature of space is measured using specialized instruments, such as telescopes and satellites, that can detect and measure the various forms of radiation present in space. This data is then analyzed to determine the temperature of a particular area or region of space.
4. How does atomic/molecular motion affect the temperature of space?
In space, atoms and molecules are in a constant state of motion, even in the apparent vacuum. This motion, along with other factors such as radiation and density, contributes to the overall temperature of space. The more energetic the motion of these particles, the higher the temperature will be.
5. Is there a temperature equilibrium in space?
Yes, there is a temperature equilibrium in space, meaning that the temperature is relatively stable and doesn't fluctuate drastically. This is due to the balance between different factors, such as radiation, density, and energy transfer, that maintain a relatively consistent temperature in space.
  • Astronomy and Astrophysics
  • Thermodynamics
  • Thermodynamics
  • Materials and Chemical Engineering
  • Biology and Medical
