bcd201115
- 20
Two metal bars are made of invar and a third is made of aluminum. At 0°C, each of the 3 bars is drilled with two holes 40cm apart. The bars are assembled into an equilateral triangle.
a)ignoring expansion of the invar, find the angles between the invar bars as a function of Celsius temperature
b)is the answer accurate for negative as well as positive temps and c) for 0°C
d)assuming the tabulated expansion coefficients are constant, solve again including expansion of the invar
e and f) find the greatest and smallest attainable angles between the invar bars
I know this is a long problem with a lot of work but can anyone at least get me started, I am stuck as far as how to even start
3. The Attempt at a Solution [/b
aluminum melts at 660°C and invar at 1427°C
