Temperature variation of resistance
In summary, the resistance of a metal wire at a temperature of 20°C is 8.1 ohms. At 90°C, the resistance is 11.45 ohms. Using the equation R=R(o)[1+alpha(T-To)], the resistance of the wire at -20°C can be calculated to be approximately 6.746 ohms, with an error of less than 10% from the correct value.
dasblack
A metal wire has a resistance of 8.10 at a temperature of 20°C. If the same wire has a resistance of 11.45 at 90°C, what is the resistance of the wire when its temperature is -20°C?
alpha=R-Ro/Ro(T-To)
alpha=11.45-8.1 / 11.45(70) = 4.18e-3
R=11.45[1+(4.18e-3)(-40)] = 9.54 ohms
But 9.54 isn't the answer...
Isn't the resistance at 20° = 8.1?
Hmm.. I did that and got 6.746. It says I am within 10% of the correct value
FAQ: Temperature variation of resistance
1. How does temperature affect the resistance of a material?
As temperature increases, the resistance of a material also increases. This is due to the fact that as temperature rises, the atoms in the material vibrate more vigorously, causing more collisions with the electrons and hindering their flow.
2. Is there a specific equation to calculate the resistance at a given temperature?
Yes, the equation is R = R₀(1 + αΔT), where R is the resistance at a given temperature, R₀ is the resistance at a reference temperature, α is the temperature coefficient of resistance, and ΔT is the change in temperature.
3. How does the temperature coefficient of resistance differ among materials?
The temperature coefficient of resistance varies among materials. Generally, metals have a positive temperature coefficient, meaning their resistance increases with temperature, while semiconductors have a negative temperature coefficient, meaning their resistance decreases with temperature. The temperature coefficient also varies with the temperature range.
4. Can temperature variation affect the accuracy of resistance measurements?
Yes, temperature variation can significantly impact the accuracy of resistance measurements. This is why it is essential to take temperature into account when measuring resistance and using the appropriate equations to compensate for temperature effects.
5. How can temperature compensation be used to improve the accuracy of resistance measurements?
Temperature compensation involves using equations or correction factors to adjust resistance measurements for temperature effects. This can be done by either measuring the temperature of the material and using the appropriate equation or using a temperature sensor to automatically adjust the resistance measurement. This helps to improve the accuracy of the measurement by accounting for the temperature variation of resistance.
