Tennis Projectile Motion Question
A tennis ball is served horizontally at a height of 2.4m and must clear a 0.9m net by at least 0.2m, leading to questions about its minimum initial velocity and landing distance. The initial vertical velocity is set to zero, and the time to fall is calculated using kinematic equations, resulting in a minimum initial horizontal velocity of 23.3m/s. For the landing distance, the same time is used to determine how far the ball travels horizontally, yielding a distance of 11.0m from the net. There is uncertainty about whether the ball should have an initial vertical velocity due to gravity, but the calculations appear consistent with tennis dynamics. Clarification on the correct approach for part b) is sought, emphasizing the importance of accurately accounting for vertical motion.
Emethyst
A tennis ball is served horizontally at a height of 2.4m, 12m from a net that is 0.9m high. a) If it is to clear the net by at least 0.2m, what is its minimum initial velocity? b) If it clears the net by 0.2m, where will it land? Neglect air resistance for both parts.
Kinematic equations, d=vt
I solved this question, but I'm not sure if I went about doing it right, especially for part b). For a) I set the initial vertical velocity to zero, found time using the equation d=v0t + (1/2)at2, and then used this value of time in the equation d=vt to find the initial (horizontal) velocity, which I calculated to be 23.3m/s. For part b) I essentially did the same as a), making the initial vertical velocity zero, calculating the time, and then plugging it into d=vt with the horizontal velocity from part a) to solve for the distance from the net. I wondering for part b) if this would be correct, for I think that the ball would have some form of initial vertical velocity because of gravity, yet my answer of 11.0m seems to make sense in the context of tennis. If anyone can show me which way would the correct method here it would be greatly appreciated, thanks in advance.
In the second part they have asked the horizontal distance between the serving point to the landing point. So find the time taken by the to fall through 2.4 m. use this time to find the distance.
  • · Replies 39 ·
  • · Replies 21 ·
  • · Replies 18 ·
